Posted: Fri Aug 26, 2011 8:48 am |
did folding mirrors come as standard on the gt/gti ?
Posted: Fri Aug 26, 2011 8:50 am |
I think its only on the gti 180, but im not 100% sure.
gt, rg and gti 180
| WIP: Black 1.6 16v XSi
Beauté Noire | |
Posted: Fri Aug 26, 2011 8:58 am |
Does it have three points on your switch?
| Team Impossible Possible
Posted: Fri Aug 26, 2011 9:26 am |
| Addaz wrote: |
| Does it have three points on your switch? |
yep left/right..and an arrow at the bottom..my left mirror aint working right...its clicking/ticking when i try to fold it in..but aint moving...
tried to open it up and investigate but could`not see much
is it time for a new mirror...or is there a fix for this ?
Posted: Fri Aug 26, 2011 9:43 am |
I take it you have a GT and not a GTi then..
With fixing it, I've no idea to be honest. Sounds like a broken motor and even a whole used folding mirror for 206's these arn't cheap
| 206 GTi 180 - 406 brembos with 283mm discs, coilovers and Sparco bucket seats | |
Posted: Fri Aug 26, 2011 9:48 am |
Will be the normal folding motor full of rust issue.
Pack the folding motor housing with Vaseline on reassembly to keep the rust away in the future.
Posted: Fri Aug 26, 2011 10:29 am |
| EuroPeugeot wrote: |
With fixing it, I've no idea to be honest. Sounds like a broken motor and even a whole used folding mirror for 206's these arn't cheap |
thought mines was a GT/GTI ??? lol
Ive stripped them apart completely, they are quite crap tbh
Motors clog with rust so easily
Posted: Fri Aug 26, 2011 10:30 am |
| Addaz wrote: |
Motors clog with rust so easily |
once cleaned out/greased are they ok or still get trouble with them ?
Posted: Fri Aug 26, 2011 10:32 am |
| MrBSI wrote: |
Pack the folding motor housing with Vaseline on reassembly to keep the rust away in the future.  | folding motor housing....is this the bit that has 3 wee philips screws holding the motor in ?
had bother gettin them out so left them case i knackered them
Posted: Fri Aug 26, 2011 10:50 am |
| Tam80 wrote: |
| MrBSI wrote: |
had bother gettin them out so left them case i knackered them |
Nope, thats the pivot point, the folding motor is inside the mirror, once inside you will need to drill the 4 rivets out carefully to take it apart.
There a pain to strip down & rebuild
Posted: Fri Aug 26, 2011 11:10 am |
| MrBSI wrote: |
| Tam80 wrote: |
| MrBSI wrote: |
There a pain to strip down & rebuild  |
a pain lol..i was lost soon as i started it lol
screws do the trick to replace rivets or rivets again ?
Posted: Fri Aug 26, 2011 11:52 am |
| Tam80 wrote: |
screws do the trick to replace rivets or rivets again ? |
Rivets are of a specalist type & I couldnt find anyone that sells them
Counter sunk self tapping screws of the correct length work just as well & are what I used.
Posted: Fri Aug 26, 2011 12:59 pm |
cool cheers again for info guys
