Latest: cogeim7
Overall: 17185
Online Now [784]:
Visitors: 783
Today: 104240
Total: 147002700
Forums › The Car › 206 Problems › failed emissions
failed emissions
sx206
PostPosted: Wed Sep 21, 2011 11:16 am Up
failed on co, limit is 0.3 my reading was 0.50.checking exhaust found like a pin hole at the rear of the back box,maybe a dumb question but is it meant to be there Question i suspect not.going to chuck some wynns in the tank and give it a good blast before next test,any advice on back box would be appreciated.
thanks in advance. Smile
206
vintageoriginal
PostPosted: Wed Sep 21, 2011 12:37 pm Up
Unlikely to be a hole in the back box. More likely a fault with the catalytic convertor or a lambda sensor.
Quiksilver: 1.6 16v Engine Conversion.
PostPosted: Wed Sep 21, 2011 12:43 pm Up
funny thing i had a vectra with 1.0 fail and to my surprise with some wynns emmissions reducer few days before and a hard run before re-test worked a treat, (only needed it to scrape through so i could get rid with 12months)
arronmee1990
PostPosted: Wed Sep 21, 2011 2:52 pm Up
I agree. Always some kind of fuel system cleaner a few weeks before the test to let it work through and then get the car nice and warm before dropping it off for the MOT gives it much more chance of passing emmisons
My Project Thread
iainlovatt
PostPosted: Wed Sep 21, 2011 3:00 pm Up
No point in using fuel cleaner waste of money, you get it in the expensive shell fuel known a V Power, Top the car up with about 20 quid worth it and keep engine running for 30-40 mins prior to test..
Should pass otherwise it will be costly!!
(My Garage)
PostPosted: Wed Sep 21, 2011 3:06 pm Up
the vectra i had that failed was full of V power and had been for a while lol Laughing (had a shell company card so didnt pay for it so always had vpower) Very Happy
£5 for some wynns stuff and passed Laughing
sx206
PostPosted: Sat Sep 24, 2011 5:57 am Up
quick follow up,used wynns twice with about 1/3 of a tank each time,driving like i stole it,emissions exactly the same result.trip to euro car parts buy cat, fit cat,emissions sorted.wish i had never heard of this snake oil stuff.wasted a good bit of time,money,petrol.lesson learnt i suppose. Smile
206
chopsim1
PostPosted: Sat Sep 24, 2011 6:32 am Up
The pin hole in the bottom of the back box is a weep hole for water. Was told this last week at the tyre/ exhaust place.
Thanks for reading
PostPosted: Sat Sep 24, 2011 6:42 am Up
Correct BUT the designed in water trap further up the system rots out the middle pipe instead Laughing
PostPosted: Sat Sep 24, 2011 6:44 am Up
It would have to have been made like this otherwise it would have failed for having a hole in the exhaust.
It's not always practical to give the car a 30 minute run before the test. I leave mine at the garage all day, and they do it whenever the mechanic gets the time. In this case, a 30 minute run would just be a waste of time and fuel as it could be sat in the car park for 6 hours before it's touched. If the garage leave it idling to warm up while doing other checks, then it's going to build up emissions anyway, then if the garage is half decent the mechanic will rev the balls off the engine before conducting the test.
Fuel additives do work, and so does Shell v-power. Both work out a similar price (if you fill the tank). Asda occasionally have offers on Redex. Worth looking in there and Tesco to find the offers.
PostPosted: Sat Sep 24, 2011 6:48 am Up
not surprise about the result at all Laughing
smiddies
PostPosted: Sat Sep 24, 2011 9:01 am Up
Could of asked them to check another car at the same time Wink
