Posted: Fri Sep 23, 2011 6:51 pm |
Hi
a mate of mine wants me to service her car for her over the weekend. Just wondering what kind of a job it is to do the fuel filter?
I've looked into the parts already & it seems the whole filter housing has to be changed. Is it just a case of disconnecting the fuel pipes then removing the housing, fit the new housing then reconnect the pipes?
I'm pressuming it's a self priming system as it's not old an old car, 2007, my 51 reg vectra 2.2dti isn't self priming & was a total PITA to get it running after changing the fuel filter
Craig
| Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes! | |
Posted: Sat Sep 24, 2011 7:02 am |
HDI is self bleeding BUT it can take a long while to start after a filter change
Posted: Sat Sep 24, 2011 7:22 am |
MrBSI wrote: |
HDI is self bleeding BUT it can take a long while to start after a filter change  |
Huh? It starts straight away if bled right
Posted: Sat Sep 24, 2011 11:55 am |
took me hardly any time at all to change the filter, primed it & it started 1st time!
Thanks anyways guys!
Posted: Sat Sep 24, 2011 11:58 am |
Yeah it's easy to change, and should start straight away when bled right
