Online Now [65]:
Visitors: 64
Today: 21630
Total: 105256376
Forums › The Car › 206 Talk › Where to get engine cover clips?
trackgti
PostPosted: Sat Sep 24, 2011 11:45 am Up
Just wondered whether there's anyone online that sells the 6 black engine cover clips that seem to shear off for a 138bhp GTI, I was amazed to see no-one on ebay has them.
When I got the car it only had one fitted (the rest snapped off) and someone had wedged some cardboard in a gap with some tape to hold the cover on! Until I can get some clips it'll be staying off.
Track toy 206, is this really a good idea? hmmm.
PostPosted: Sat Sep 24, 2011 11:48 am Up
Main dealers cheap enough for things like that.
PostPosted: Sat Sep 24, 2011 11:56 am Up
An outrageous 29p each from Peugeot/Citroen Surprised
Part Number 0250 67
PostPosted: Sat Sep 24, 2011 12:04 pm Up
They do come in minimum order quantities normally.
Dutch-HDi
PostPosted: Sat Sep 24, 2011 12:54 pm Up
I got sick to death od buying em, so i got four bolts 8 nuts and put bolts in with two nuts each then tightened up then cuts the heads off, removed the nuts and put on wing nuts on and never looked back, never break the stupid fench plastic clips again, bad design P's me off lol
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
PostPosted: Sat Sep 24, 2011 12:55 pm Up
Different engine....different clips
Dutch-HDi
PostPosted: Sat Sep 24, 2011 1:02 pm Up
I certainly appreciate that the clips are for two different engines and the parts may even be a different part # but it’s the principal to adapt a bad design still may have some benefit or just buy loads to have as spares for future use
PostPosted: Sat Sep 24, 2011 1:44 pm Up
They are totally different.
HDi are twist on s***ty things, the GTi ones are the same as on the fuse box
trackgti
PostPosted: Sat Sep 24, 2011 2:26 pm Up
Thanks for the replies guys, I expect i'll get some replacement clips then, but if they snap i'll certainly be looking at alternatives!
