Posted: Mon Sep 26, 2011 11:32 am |
Hi all
Just installed new headunit, after starting up headunit does not power on, speedo clocks nor headlights work, however electric windows and air con does
Can anyone shed light on this? Car starts up/drives fine apart from no speedo clock.
Mike
Posted: Mon Sep 26, 2011 11:35 am |
Tryed the fuses??
Blown some fuses by the sounds of it
Posted: Mon Sep 26, 2011 12:21 pm |
F U S E
Posted: Mon Sep 26, 2011 1:23 pm |
how do i check fuses? thanks for the quick reply haha
Mike
Posted: Mon Sep 26, 2011 1:25 pm |
Fowla wrote: |
Mike |
Year of 206 needed.
There has been 2 totaly different electrical systems used by Peugeot on the 206 over the years & the fuse boxes are totaly different.
Posted: Mon Sep 26, 2011 2:22 pm |
54 plate, phase 2, multiplex i think? im new to all this pug stuff haha
Mike
Posted: Mon Sep 26, 2011 2:27 pm |
Fuse 15 in the BSI 15 amp fuse & there the small blade type.
Shutting the BSI down correctly before you pull any fuses out would be a good idea.
Odd you have managed to blow the radio fuse on a multiplexed 206 & it actually starts & runs
They normally immobilise themselves with the fuse blown
Posted: Mon Sep 26, 2011 3:00 pm |
how do i shut down the bsi?
and it is the speedo clocks/screen in the top center of the dash aswell that displays time and date
are they the same fuse? and would the fact these have gone along with the headunit point to a different problem?
Mike
Posted: Mon Sep 26, 2011 3:05 pm |
I blew that fuse on Matt's Mux'ed 206 and that started
Was at like 10pm at night and all the shops were closed so we had to take the 15amp fuse out of the rear wiper and use that
Posted: Mon Sep 26, 2011 3:18 pm |
Lmfao
Just the small blade type that you usually find in the back of headunits? Those sorta fuses? And Where is the fusebox? Had the 206 for just over a week, diving in the deep end hehe
Mike
Posted: Mon Sep 26, 2011 3:21 pm |
They are mini fuses not regular ones
It's where your knees are under the steering wheel
Posted: Mon Sep 26, 2011 3:40 pm |
Is the one fuse for the headunit and speedo clocks? or have i blown more than one fuse?
Posted: Tue Sep 27, 2011 4:21 am |
Sorry for double post but where is fuse 15 and which fuse can i temporarily rob to fix it? Rear wiper? Which fuse is that?
Anyone online please reply so i can tinker during my lunch at work hehe
