Latest: tebas93089
Overall: 17179
Online Now [109]:
Visitors: 108
Today: 15738
Total: 138117714
Forums › The Car › 206 Problems › Can't Fill Up All The Way
SteDuval1985
PostPosted: Sun Sep 25, 2011 11:31 am Up
In my old 1.9d I got about 50 litres of fuel from near empty, but on my 1.4, 06 plate I'm getting about 40 litres in (from near empty) before I can't put anymore in. The gauge also isn't showing that the tank is full; the highest it'll go to is about halfway between the first quarter of the gauge. Any suggestions as to why this may be?
PostPosted: Sun Sep 25, 2011 11:33 am Up
If the fuel pump is cutting off when you are filling up, then it's the gauge that's faulty not your tank Wink
Deceitful
PostPosted: Sun Sep 25, 2011 11:42 am Up
when did you notice it? like.. was this after you changed something?
Peugeot 206 Zest 1.1 5 door
Mattie-RS
PostPosted: Sun Sep 25, 2011 12:06 pm Up
Must be a hole or summot
SteDuval1985
PostPosted: Sun Sep 25, 2011 2:16 pm Up
The pump cuts off when the tank is at capacity but I thought 206's tanks are 50 litres, so every time I fill up the pump is cutting off at 40 litres - 10 below capacity. The gauge seems to be right because it's showing that that 10 litres isn't in the tank, but the pump is cutting off because its nearing capacity Confused
SteDuval1985
PostPosted: Sun Sep 25, 2011 2:18 pm Up
Had the car 3 months and it's done it ever since. I've not changed anything on it.
PostPosted: Sun Sep 25, 2011 2:38 pm Up
When the fuel light is on, how much fuel does it take to fill it up?
SteDuval1985
PostPosted: Sun Sep 25, 2011 3:31 pm Up
40 litres or so. Today I'd driven about 20 miles on the fuel light before I filled up. I think the manual says you have 30 miles or so left in the tank at that point so I presumed that the tank was nearly empty. I got 40.8 litres in until I couldn't get any more in.
PostPosted: Sun Sep 25, 2011 3:47 pm Up
When the fuel light comes on you have a gallon left
SteDuval1985
PostPosted: Mon Sep 26, 2011 12:30 pm Up
I can still only get 40 litres in and the gauge isn't reaching the top, even though the tank is meant to be 'full'.
PostPosted: Mon Sep 26, 2011 12:34 pm Up
BSI reboot would be my first port of call Wink
