Latest: cogeim7
Overall: 17185
Online Now [536]:
Visitors: 535
Today: 218528
Total: 147116722
Forums › The Car › 206 Problems › Engine Noise from Peugeot 206 LX
m3g4tr0n
PostPosted: Thu Nov 10, 2011 9:33 am Up
is the belt making this noise?
youtu.be/WQuIcRQnUss
thanks
PEUGEOT 206 1.4 LX 2003 (TU3JP / KFW)
PostPosted: Thu Nov 10, 2011 9:58 am Up
Sounds more like its catching on something or a bearing is going.
cartoonhead
PostPosted: Thu Nov 10, 2011 10:57 am Up
tensioner / roller bearing on its way out
m3g4tr0n
PostPosted: Thu Nov 10, 2011 12:33 pm Up
is this the tensioner?
and can the roller bearing be replaced or do i need a new tensioner
thanks
cartoonhead
PostPosted: Thu Nov 10, 2011 12:47 pm Up
lookin at the pic i would say that one arrowed is the tensioner and the one under that is the roller.
fit a new one Thumb Up
Antknee
PostPosted: Thu Nov 10, 2011 12:53 pm Up
wouldnt drive it incase it goes... mine did but was lucky enough for it to not destroy the engine...
get a new belt while your at it Razz
m3g4tr0n
PostPosted: Thu Nov 10, 2011 1:25 pm Up
@cartoonhead
do you mean change the tensioner or the bearing?
any part numbers or links of where i can get one?
the car is a
2003 PEUGEOT 206 1.4 LX 3dr Auto [AC] Hatchback
cartoonhead
PostPosted: Thu Nov 10, 2011 3:19 pm Up
remove the belt and if the tensioner is wobbly just replace the whole thing.
as Antknee said , change the belt while its off
not suggesting to get this one ( try local motor shop ) but its what you are looking for
TENSIONER
PostPosted: Thu Nov 10, 2011 6:02 pm Up
Antknee wrote:
wouldnt drive it incase it goes... mine did but was lucky enough for it to not destroy the engine...get a new belt while your at it Razz
Can this happen with the aux belt?
I thought it was the cam belt that casues damage if it goes.
But ye new belt too.
m3g4tr0n
PostPosted: Fri Nov 11, 2011 1:17 pm Up
ok, just took a picture and saw that there's two tensioners (no 5 & 6)?
see link
www.peugeot206cc.co.uk...bbmek3.htm
POWER STEERING AIR CONDITIONING
(58) Dynamic tensioner roller .
(59) Alternator .
(60) Roller tensioner .
(61) Ancillaries drive pulley .
(62) Air conditioning compressor .
(63) Power steering pump .
PostPosted: Fri Nov 11, 2011 1:22 pm Up
Yeah if it jams the bottom crank pulley
cartoonhead
PostPosted: Fri Nov 11, 2011 2:49 pm Up
5 is the roller 6 is the tensioner , best bet is get the belt off and see which one has any play / wobble on it.
Have a look HERE to see what happened to mine when the aux belt split and wrapped it's self around the crank pully Wink
PostPosted: Fri Nov 11, 2011 7:49 pm Up
Dam, I din't know that. Shocked
m3g4tr0n
PostPosted: Sat Nov 12, 2011 5:24 pm Up
what would you is the difficulty of this job?
would i need any special tools to remove the tensioner and belt?
what's the difference between these belts and which one is shown on the picture posted above
Serpentine Belt
Auxiliary Belt
Ancillary Drive Belt
Timing Belt
Cam Belt
is any of this stuff covered in the Haynes Guide? will be getting one next week.
thanks
paul_c
PostPosted: Sun Nov 13, 2011 6:37 am Up
No
Serpentine Belt
Auxiliary Belt
Just semantics, names for the same thing
m3g4tr0n wrote:
Timing Belt
Cam Belt
thanks
Its all covered in the Haynes manual, you're probably best waiting for it to arrive and have a good read through the relevant sections.
