Latest: Worthy967
Overall: 17143
Online Now [521]:
Visitors: 520
Today: 89458
Total: 115574463
Forums › The Car › 206 Problems › Reversing lights work then dont...
StephXSi
PostPosted: Sat Oct 01, 2011 1:15 pm Up
Well i was reversing onto the garden earlier and i noticed in the reflection of the greenhouse behind me that my reversing lights weren't working, sat for a while putting it back in neutral and then back into reverse and they still weren't working and then all of a sudden they just started working again.
Just been onto the garden to check again and it did the same again, no reverse lights coming on and after about 5 times of putting it in reverse they all of a sudden started working again.
Has anyone ever had this problem before, ive done a quick search on here and only found problems where peoples reverse lights werent working at all.
If it was a fuse or the reversing switch that was at fault then wouldnt the reverse lights just not work at all instead of not working and then all of a sudden working again?
Thanks for any help in advance, oh and i have a 2004 1.6 xsi model if that helps Smile
leigh_boy
PostPosted: Sat Oct 01, 2011 1:18 pm Up
either a bad connection or the reverse sensor on the gear box may have a bad connection or need replacing
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
AshH
PostPosted: Sat Oct 01, 2011 1:29 pm Up
Yeah myt just be a loose connection! Take the plug out and plug it back in!
Team - 180
Team - ATM!!!
StephXSi
PostPosted: Sat Oct 01, 2011 1:34 pm Up
onThe plug on the sensor that sits ontop of the gearbox do you mean? How easy is this to get to? Thanks
207 GTi
AshH
PostPosted: Sat Oct 01, 2011 1:51 pm Up
No i mean to the rear lights themselfs!
Team - 180
Team - ATM!!!
leigh_boy
PostPosted: Sun Oct 02, 2011 1:42 am Up
i would be looking more at gear box engm dirty contact or similar, normaly on the bottom / end of the gear box.
*DEAD*206 Gti 138
PugJH
PostPosted: Sun Oct 02, 2011 2:15 am Up
1st thing i did on my old 206 was fit a new reverse switch.
5minute job.
Looks like this
www.ebay.co.uk/itm/REV...5646304d87
WIP: Black 1.6 16v XSi
Beauté Noire
PostPosted: Sun Oct 02, 2011 2:16 am Up
Check the fuse first of all. Don't just look at it, use a multimeter to check it hasn't blown.
Disconnect the connector from the gearbox reversing switch, select reverse gear (engine turned off) and using the continuity setting on a multimeter check if the switch is working.
If it's working check to make sure there is current reaching the bulbs. Again using the multimeter (change setting to measure DC 12v) remove one of the bulbs and touch the multimeter probes onto the bulb holder connections. You will need the ignition on and reverse gear selected. BE CAREFUL NOT TO SHORT ANYTHING OUT when doing this stage.
If you have current reaching the bulbs, then check the bulbs themselves haven't blown.
shell-vt
PostPosted: Sun Oct 02, 2011 2:26 am Up
Trade Rating: +46
not needed for mot anyway so wouldent worry..
york 16,3
StephXSi
PostPosted: Sun Oct 02, 2011 4:04 am Up
Would have thought you would have needed your reversing lights working for your mot? Will check the fuse first then check the reversing switch. I've had a look in my manual and can't seem to find which fuse is for the reversing lights? Does it have a fuse for those? My fuse box is underneath the steering wheel if anyone can help me with what fuse I need to check. Thanks guys Smile
PostPosted: Sun Oct 02, 2011 4:06 am Up
Why wouldn't you? :S
shell-vt
PostPosted: Sun Oct 02, 2011 4:07 am Up
Trade Rating: +46
check mot regs or ask anyone who works in a garage..
york 16,3
PostPosted: Sun Oct 02, 2011 4:10 am Up
Front fogs and reverse lights aren't tested on a MOT
PostPosted: Sun Oct 02, 2011 4:11 am Up
Hmmm.. Never knew that. They are one of our daily van checks at work, so presumed that they were. (I knew fogs weren't).
PostPosted: Sun Oct 02, 2011 4:19 am Up
Nah, they aren't required by law so are classed as accessory lights and not MOT testable Smile
