Latest: Kifi69
Overall: 17183
Online Now [216]:
Visitors: 215
Today: 124387
Total: 144142212
Forums › The Car › Solved 206 Problems › 206 High revs but only after 3 minutes from cold??!!!!!
djs76
PostPosted: Mon Oct 24, 2011 6:12 pm Up
Hi all
Hope someone can help shed some light on this little problem? I have a '99 1.1 peugeot 206 that I have just done the head gasket on.
Before doing hg car misfired on low revs. ticked over (albiet on 3!) well.
Post hg. start car from cold and for first 3 mins and it will tick over around 950 - 1000 as I would expect on choke. revs happily with no untoward noises and behaves exactly as it should. After this, as soon as there is a little warmth in the engine, revs go up to 4000!!!! tap the accelerator and engines starts to die. few or no revs. push accelerator harder and she picks up and revs again. haven't let the car run more than a couple mins so cant say what it does after that. Plugs I took out were all sooted up so running too rich?
Whats been done -
New lambda sensor
New coil pack
New hg
New antifreeze
new belt and tensioner - timing set up with hole in cam wheel and crankshaft
New plugs
isv cleaned out
Gut instinct points to one of the sensors is breaking up when it starts to get warm. Annoying as wasn't over revving before! Alternatively the ECU is kaput?. Thought about temperature sensor feeding untrue info to ECU as it starts to warm?
Any help much appreciated. Dont fancy £200 quid on a new ecu to find out its a 20 quid sensor!
Got down to 2 now back to 5!
PostPosted: Tue Oct 25, 2011 3:46 am Up
The 206 I service has the same issue.
I've changed the ICV and got a new MAP sensor in the post.
djs76
PostPosted: Tue Oct 25, 2011 5:25 am Up
Thanks guys. It was indeed the temp sensor. All running sweet as a nut!
cheers
Deano
