Posted: Mon Oct 03, 2011 11:54 am |
Are there cables near the boot to connect a pair of oval
speakers in the parcel-shelf or is dissasembly required of the panels
to pick-off the speaker lines from the HU?
It's a 3-door...
Posted: Mon Oct 03, 2011 11:55 am |
6x9's are shocking sound quality. Fit some decent components
You need to run the wires via a amp ideally, if not just piggy back the rear speakers
Posted: Mon Oct 03, 2011 11:59 am |
| Lee wrote: |
You need to run the wires via a amp ideally, if not just piggy back the rear speakers |
1) There are no rear speakers in there at the moment.
2) I now what you mean but it's fine for my purposes as I regularly
use 15KW setups for work so..
depends how you want to set it up, as Lee said, people generally piggy back of the rear speakers. if you want a good sounds, put good componants in your front door, up rated tweeters on the a-pillar and a sub in the boot, will give the best sound possible
Posted: Mon Oct 03, 2011 12:09 pm |
So can I get to the cables from the boot or will the panels, seatbelts etc have to come-off?
Posted: Mon Oct 03, 2011 12:18 pm |
why bother? may aswell wear your glasses backwards for all the good they will do.
| 1992 White 205 Rallye - S2 Engine
2000 Saxo VTS MKII - Silver - For Sale | |
Posted: Mon Oct 03, 2011 12:29 pm |
panels will need to come of to get to the speakers. if i remember right that means the rear seats coming out as well
Posted: Mon Oct 03, 2011 12:51 pm |
| DaSneakyGit wrote: |
| why bother? may aswell wear your glasses backwards for all the good they will do. |
Cheers but I think I have a pretty good idea regarding 'what good they will do' and that is not what I'm asking anyway.
P.S. I don't wear glasses, only ear-plugs (read the thread).
| greg.mitchell350 wrote: |
| panels will need to come of to get to the speakers. if i remember right that means the rear seats coming out as well |
Yes its seats, belts, panels and window seal for the speakers but I only want to connect to the cables and fit on the shelf instead.
Posted: Mon Oct 03, 2011 12:54 pm |
Why not just get a bass tube?
Posted: Mon Oct 03, 2011 12:56 pm |
| Lee wrote: |
| Why not just get a bass tube? |
Amp needed and I want the full range for the people sitting at the back..
Bass tubes have them built-in, like the OEM one
Posted: Mon Oct 03, 2011 12:58 pm |
| V9977 wrote: |
| Lee wrote: |
Amp needed and I want the full range for the people sitting at the back.. |
That's why I'm bothering with the whole thing tbh..
