Latest: Stu-mill
Overall: 17131
Online Now [57]:
Visitors: 56
Today: 3551
Total: 104913218
Forums › The Car › 206 Problems › Radiator fan for a 206GTI
138Andy
PostPosted: Sat Mar 03, 2012 6:15 am Up
Not Quite sure what the problem is but the Radiator cooling fan wont actually turn on until the cars basically redlining the warning sign to say its overheated. any ideas ? :/ or what i could check ?
PostPosted: Sat Mar 03, 2012 7:22 am Up
Does it work with the air conditioning on? If it does then it's not the fan or wiring/relays at fault.
If it doesn't work when the air conditioning is on then chances are the wiring and relays will be heavily corroded or even broken. It's not difficult to replace the wiring and clean up the terminals on the relays.
TheGTIlad
PostPosted: Sat Mar 03, 2012 7:30 am Up
My guess is the coolant temp sensor is at fault. what i would do is check the resistance of the coolant temp sensor.
PostPosted: Sat Mar 03, 2012 7:36 am Up
I have a working Coolant sensor, as well as a thermostat, radiator, relay, and radiator if you need any parts
I also could come run a diag if you want, to see if that can detect the problem, and run a few tests
PostPosted: Sat Mar 03, 2012 7:43 am Up
Another quick check is to unplug too coolant temp sensor. That way the ECU doesn't know how warm the engine is and so to protect the engine from getting too hot it puts the fan on.
If your temp guage is normal then the coolant sensor will be ok.
138Andy
PostPosted: Sun Mar 04, 2012 6:04 am Up
wouldn't unplugging the coolant sensor effect performance and be rather noisy leaving the fan on ? Smile
when i get time think ill rip it out and see if all the wiring is still in place Smile thanks guys Smile
PostPosted: Sun Mar 04, 2012 6:15 am Up
You only need to do it temporarily to check it. Not to leave it like it.
PostPosted: Sun Mar 04, 2012 9:45 am Up
You don't even need to drive it to test!
If the fan was noisy wouldn't that tell you something??? Like the fan is working???
138Andy
PostPosted: Sun Mar 04, 2012 10:18 am Up
ohh nono the fan comes on only when the temperature reading is in the red and the car goes batshit telling me to stop last time i was in traffic the radiator pipe just exploded from the pressure that had built up :/
PostPosted: Sun Mar 04, 2012 10:39 am Up
Well to me that suggests the relay, resistor or wiring to the relay terminals is knackered.
So have you switched the engine on with the coolant sensor disconnected?
