Online Now [135]:
Visitors: 134
Today: 48967
Total: 138727929
Forums › The Car › 206 Problems › Exhaust strap / bracket
kevbeans
PostPosted: Fri Oct 07, 2011 6:36 am Up
The strap which goes round my manifold has snapped. Just been to peugeot and been told it comes as part of the manifold at £130! Is there an aftermarket part or is it a case of welding bits on, not got a welder so would be easier for me to buy a new strap. This has probably been covered loads of times in the past but using the net via my phone so can't search.
new to the whole peugeot thing!
PostPosted: Fri Oct 07, 2011 6:38 am Up
Strap around the manifold??
kevbeans
PostPosted: Fri Oct 07, 2011 6:58 am Up
Back box has a metal strap around it which fixes to the exhaust hanger, bottom part of this 'strap' is corroded.
PostPosted: Fri Oct 07, 2011 7:02 am Up
You said manifold in the first post.
That strap is joined to the back box
kevbeans
PostPosted: Fri Oct 07, 2011 7:26 am Up
yeah dunno why i put manifold. So no one makes an aftermarket strap. Seems crazy to have to spend £130 on a backbox just because the bit which fixes it to the car has failed.
Guess I'll be looking for a local welder.
Jack4273
PostPosted: Fri Oct 07, 2011 7:30 am Up
Might aswell just save abit more dollar and get a supersprint exhaust system Razz
Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Very Happy
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html
paul_c
PostPosted: Fri Oct 07, 2011 7:34 am Up
Does a back box really cost £130? I'd have thought a more realistic price would be £25-£40. I imagine if the strap has snapped off due to corrosion, the rest of the exhaust system won't be much better?
EuroPeugeot
PostPosted: Fri Oct 07, 2011 7:57 am Up
Peugeot/most main dealer prices for any part of the exhaust system is quite high.
Save up and buy a nice cat back exhaust system?
paul_c
PostPosted: Fri Oct 07, 2011 8:00 am Up
Just phone around a couple of exhaust fitting centres in the local area for a good price? There is likely no difference in quality between the Peugeot-supplied exhaust and a decent one from an exhaust centre - except the price.
Dutch-HDi
PostPosted: Fri Oct 07, 2011 10:35 am Up
id try asking at one of the local tyre n exhaust fitters if they sell straps, might be able to modify another one
Or try this seller on ebay ive used these before for the van and highly recomend them
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
pug-206-boy
PostPosted: Fri Oct 07, 2011 10:50 am Up
do you mean like the little metal arms that come off the backbox and go on the rubber mounts??
kevbeans
PostPosted: Fri Oct 07, 2011 10:55 am Up
Cheers Dutch, I'll see what price he can dfo one for and also have a look round local exhaust places. No point getting any kind of sports exhaust as i've only got a 1.4 hdi van!
paul_c
PostPosted: Fri Oct 07, 2011 11:26 am Up
If its simply the metal rod, then plenty of places can sell metal rod for you. For example, B&Q. However, you'll want it welded to the back box or pipe, whereever it is; and probably bent to shape too. If there's enough clean metal to weld a new support to, then a welder will have no problems doing it. They might be able to do a repair at a local garage, for example. The danger is the cost of their time will exceed the cost of a new backbox. If you can weld yourself, then no worries. I could do it for you but I imagine the travel costs to-from Southport (35 miles each way) would make it not worthwhile. Also it would have to be a dry day, I'm not welding in the rain!
Dutch-HDi
PostPosted: Fri Oct 07, 2011 11:37 am Up
think the OPs on about a metal band (strap) that goes round the back box then onto the hangers have used them many times on diffrent cars but havnt changed the 206 backbox myself would imagine should be able to find something at the local fitters that would adapt
