Posted: Thu Oct 13, 2011 12:19 pm |
hey guys
i posted a thread a while ago thinkin i'd fixed the problem with my pug. turns out i was wrong
it still keeps flashing/turning its dipped headlights on on its own, but when this happens my windscreen wipers work on intimitant & won't turn off.
the bit thats confusing me is when all this happens it locks me out of the whole unit.
e.g i can't indicate or use my winscreen wash. i dont think its anything do with my comms unit cuz the actual mechanism cancels like it would if my indicators were working.
i've also still got the airbag warning lights on aswell.
it's beginning to annoy me cuz its seen as a distraction to other drivers
Any ideas what i need to do to fix this ? i'm thinking maybe its the battery or a dodgy electrical connection somewhere
Cheers for any help
Posted: Thu Oct 13, 2011 12:20 pm |
Sounds like you have a bad case of Casper
Posted: Thu Oct 13, 2011 12:23 pm |
| Lee wrote: |
| COM is f****d. Needs a new one |
Posted: Thu Oct 13, 2011 12:27 pm |
| Dillon wrote: |
| Lee wrote: |
i dont seem to think it is the comms unit, it cancels like it should if my indicators worked on my dashboard this si why i'm confused and think its somethin to do with the electrics
Posted: Thu Oct 13, 2011 12:34 pm |
| Pugsy wrote: |
| Dillon wrote: |
| Lee wrote: |
i dont seem to think it is the comms unit, it cancels like it should if my indicators worked on my dashboard this si why i'm confused and think its somethin to do with the electrics | its not the car its the driver...
Posted: Thu Oct 13, 2011 12:44 pm |
I would strongly advise you to try another comms unit before you think about anything else. You don't even need to mount it to the rack just unplug the old one and connect it to the new one.
Posted: Thu Oct 13, 2011 12:53 pm |
| Rob2859 wrote: |
| I would strongly advise you to try another comms unit before you think about anything else. You don't even need to mount it to the rack just unplug the old one and connect it to the new one. |
I strongly suggest it is the comm unit, everything may cancel as they should, but it may be an actual fault stored in the unit itself. I advise a new comm, if that fails to do it, then it may possibly be a short in the wiring.
Posted: Thu Oct 13, 2011 12:55 pm |
Apart from the obvious which would be the com unit, have you tried a BSI reset?
Posted: Thu Oct 13, 2011 12:59 pm |
cheers guys looks like i'm gonna have to throw some money at it can't not have a car with all the extra hours i'm gettin at work at the mo and no i havent tried a BSI reset yet if the comms unit doesnt fix it then i'll give it ago
