Latest: Kifi69
Overall: 17183
Online Now [312]:
Visitors: 312
Today: 25561
Total: 144172626
Forums › The Car › 206 Talk › ppt20 to ppt40
ppt20 to ppt40
karimali831
PostPosted: Thu Oct 13, 2011 4:26 pm Up
hello!
I converted clock (ppt20) to MFD (ppt40) and working fine but have two questions. Middle bulb is gone, anyone know the name of the bulb? Other question is it normal for the engine to fail first time when I disconnect positive terminal then connect it again? This is what happened when I did this and the wiring. I turn over and it doesn't rev high enough. It works always second time but if it's something that needs to be done then I'd like to know. Smile
thanks anyone.
206 GTI 180
ukskater01
PostPosted: Fri Oct 14, 2011 12:57 am Up
The bulbs are 501 but it's best to get 501 LED's, got mine from eBay. I had to bend the contacts on them to get them working.
Not sure about the engine issue, sorry mate
karimali831
PostPosted: Fri Oct 14, 2011 9:23 am Up
cheers! but no longer needed it as I just replaced it with clock display bulb Smile
206 GTI 180
karimali831
PostPosted: Sat Oct 15, 2011 10:44 am Up
is the ppt40 mfd suppose to dim out when lights are on just the same as the ppt20 clock?
206 GTI 180
