Posted: Fri Oct 21, 2011 5:10 am |
Posted: Fri Oct 21, 2011 8:12 am |
You need to tweak some settings in the BSI configuration set up & that means Peugeot Planet time
Also if you fancy an upgrade to the standard 206 RD3 single cd / radio now would also be the time to do it as you could get that VIN coded at same time.
Posted: Fri Oct 21, 2011 8:15 am |
yea u have activate it in BSI
Posted: Fri Oct 21, 2011 12:40 pm |
Posted: Fri Oct 21, 2011 4:43 pm |
Thats a RD3, still the same answer, needs the BSI configuration set up adjusting with Peugeot Planet software.
