Latest: tbafonso
Overall: 17130
Online Now [183]:
Visitors: 182
Today: 61053
Total: 104250670
Forums › The Car › 206 Talk › Caliper Bolts
Caliper Bolts
joshack
PostPosted: Mon Oct 24, 2011 4:31 am Up
What size are they? and where would i get some!
Ones fell out on me and I need one desperatly. Cheers
drive:206 lx diesel
Mrs_Howey
PostPosted: Mon Oct 24, 2011 7:06 am Up
Unless you get one from a scrappy, the normal come as part of the brake changing set Smile They came in my set from peugeot but was like £22
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
PostPosted: Mon Oct 24, 2011 7:11 am Up
You talking about the 19mm bolts or the smaller 13mm bolts? Either way, go to the Peugeot dealer.
joshack
PostPosted: Mon Oct 24, 2011 9:17 am Up
Dealers want £45 for them!
drive:206 lx diesel
PostPosted: Mon Oct 24, 2011 9:35 am Up
Are you looking at the caliper sliders? They are expensive. The 13mm bolts come with the sliders though.
joshack
PostPosted: Mon Oct 24, 2011 9:37 am Up
The 2 19mm ones. Only need the one, but they only come part of a kit for £45
drive:206 lx diesel
PostPosted: Mon Oct 24, 2011 9:41 am Up
They are definately available on their own.
joshack
PostPosted: Mon Oct 24, 2011 9:51 am Up
Fella said thats all they can get unless I have to ask for a different model maybe?
drive:206 lx diesel
PostPosted: Mon Oct 24, 2011 9:53 am Up
Id be more worried about the state of the thread as bolts dont normally just fall out.
M12 x 1.5 bolt 35mm long.
Peugeot / Citroen part number 4405 17 Caliper screw £3.58
joshack
PostPosted: Mon Oct 24, 2011 9:56 am Up
The thread was fine inside the carrier, and cheers mate thats spot on!
drive:206 lx diesel
Part number is 440517. Those are the 19mm bolts that fix the caliper to the hub.
joshack
PostPosted: Mon Oct 24, 2011 10:05 am Up
Just rang in then ordered them should be there in the morning. Cheers lads
drive:206 lx diesel
