Latest: SA01
Overall: 17138
Online Now [60]:
Visitors: 59
Today: 10802
Total: 111257368
Forums › The Car › 206 Talk › Wiring Required for Electric Folding Mirrors
SteDuval1985
PostPosted: Thu Oct 13, 2011 8:22 am Up
I've done a search on electric folding mirrors but I'm a bit confused on exactly what wires are required for this mod.
First of all, I've checked my cabin loom (where the mirror switch will go) and I have the mirror plug with 10 wires coming from it, so I assumed I can go ahead and do this mod.
My car's an 06 Verve and doesn't have the mirror plugs, so I've managed to get hold of two door looms from a 180 that I expected would allow me to connect the mirrors up. Both looms have 9 wires going into the plugs.
However, I've read one thread on here that says to do this mod there should be 9 wires on the passenger side and 7 on the driver's side. Is this from the looms or the actual mirrors?
If I have 9 in both looms is it possible I have two passenger looms?
arronmee1990
PostPosted: Thu Oct 13, 2011 10:11 am Up
I don't know about the number of wires on each side of the loom but they best bet would be to get the mirrors and looms from the same car if possible. That's what I did anyway. You may need the bsi updating but I wouldn't have thought so being a 2006
My Project Thread
PostPosted: Thu Oct 13, 2011 10:12 am Up
You need 9 wires in the pass and 7 in the drivers, in the door loom for it to work
You need 10 at the switch side
PostPosted: Thu Oct 13, 2011 10:14 am Up
BSI updating? Eh? Confused
dont need them from the same car either lol
SteDuval1985
PostPosted: Thu Oct 13, 2011 11:37 am Up
So the connector on the passenger loom should have 9 pins and and the connector on the driver loom should have 7 pins?
PostPosted: Thu Oct 13, 2011 3:16 pm Up
Fit the door looms, fit the switch & mirrors, job done.
Reason there is 9 wires in the drivers door loom is its far easier & cheaper to just make one standard folding mirror door loom with the 9 wires in Wink
arronmee1990
PostPosted: Thu Oct 13, 2011 4:15 pm Up
Only going on what someone told me when I asked but I didn't need mind doing.
I only said it'd be easier to get them from the same car. Less hassle if you can do this
My Project Thread
SteDuval1985
PostPosted: Fri Oct 14, 2011 2:59 am Up
Cheers MrBSI Wink ; this is what I assumed when I bought the two looms but just needed to doublecheck before I went and bought the mirrors. Plus, the guy I bought them from has just confirmed that they're both looms from the same 180. I've just bought the mirrors so once they arrive I'll go about fitting them.
PostPosted: Fri Oct 14, 2011 3:02 am Up
Need to check the switch too. Just because you are fitting a loom with 9 wires, doesn't mean the cabin loom wiring will magically be there
SteDuval1985
PostPosted: Fri Oct 14, 2011 3:43 am Up
This was the first thing I checked as you stated to do to the guy in this thread...
www.206info.co.uk/Foru...rrors.html
In my car, there are ten wires attached to the connector that will attach to the electric mirror switch.
SteDuval1985
PostPosted: Wed Nov 02, 2011 7:37 am Up
Thinking I was clever and had everything to do this mod, last week I went ahead and tried to do it. The result wasn't so promising Embarassed
When fitting the door looms, I found that the bulky plug at the end of the 180 door loom doesn't match the connector in my car.
The 180 connector is black / red with two horizontal lines of 8 pins in each line, and also has an extra blue connector:
[img]
Uploaded with ImageShack.us[/img]
My existing car loom's connector is yellow / blue and has a different pin arrangement:
So, if I get the interior loom out of a 180, to match the 180 looms I have, could I go ahead and complete this mod? Confused
