Online Now [247]:
Visitors: 246
Today: 76917
Total: 142587334
Forums › The Car › 206 Problems › Squeaky Rear
Squeaky Rear
Ruffy_206
PostPosted: Fri Oct 21, 2011 11:43 am Up
Custom - Gold Stars
over the last few days i have got a few bad squeak comming from the rear beam
it happens when going over bumps/lumps not so much big bumps.
i have checked the dampers a tight. they are only 4 months old so at the present am gone to rule out they are nacked. but am going to try my old one just incase
ARB looks tight and is pulled up.
what else could it be? the trailing arms dont seem to have much play so hoping its not the bearings
any suggustions?
Ta Smile
dopey
PostPosted: Fri Oct 21, 2011 11:46 am Up
I rekon spare wheel cage needs tightening thats what mine is!!
Ruffy_206
PostPosted: Fri Oct 21, 2011 11:55 am Up
Custom - Gold Stars
have not got on and the boot is tight.
puggy206
PostPosted: Fri Oct 21, 2011 1:02 pm Up
try making sure your back seats are fully clipped in place. My old seats used to squeak because they had become loose in the clip.
Citroen DS3
D-style +
1.6 VTI
Alex90
PostPosted: Fri Oct 21, 2011 3:25 pm Up
its 100% rear axle mate its big minus of ours 206
DIESEL POWER!!!
Andy180
PostPosted: Fri Oct 21, 2011 3:33 pm Up
Wouldn't say its 100% rear axle it could be the spare wheel cage as mentioned above.
GTI 180
Antknee
PostPosted: Fri Oct 21, 2011 3:35 pm Up
already said he doesnt have one Razz
could be the bushes waring maybe :S or exhaust mounts rubbing? just a thought
Andy180
PostPosted: Fri Oct 21, 2011 3:39 pm Up
Haha didnt see that think ive had 1 to many beers 2nite
GTI 180
Linkpad
PostPosted: Mon Oct 24, 2011 6:54 am Up
God damn Rear axle how much labour is to replace one ?
Boo
PostPosted: Mon Oct 24, 2011 6:57 am Up
Its only 4 bolts that hold it on & disconnect handbrake cable's, rear brake pipes & abs wiring.
Shouldnt take that long to drop it of & replace it.
chris_rock206
PostPosted: Mon Oct 24, 2011 9:19 am Up
there's a squeak coming from my rear left which sounds like its the bush thats went and it only squeaks like you have said when you go over bumps and all, haven't got round to replacing it yet Razz
Ruffy_206
PostPosted: Mon Oct 24, 2011 3:09 pm Up
Custom - Gold Stars
solved it. read up quite a bit on dare i say it saxo and 106 fourms and alot of them have trouble with the arb end plates comming a bit lose and rubbing. hence the squeak.
when i checked it out the first time i just made sure the arb was pulled up and the two 13mm bolts tight i didnt think to take a hammer and smash to plate in,
now have no noise what so ever. might be worth giving it a try for anyone out their with a squeaky rear!
