Posted: Thu Oct 27, 2011 10:02 am |
| Car: Peugeot 206 1.1L Look 2002 | |
Posted: Thu Oct 27, 2011 10:06 am |
indicator?
Posted: Thu Oct 27, 2011 10:08 am |
Was going to say possibly H7 connections but it looks the wrong size totally for it.
Posted: Thu Oct 27, 2011 10:10 am |
I thought that, but the indicator is working and the wire isn't long enough to stretch across.
Do you see the hole punched out in the metal just under the socket? The rectangular hole?
The socket happens to be exactly the same size as that, and it sort of sits into the groove.
I was wondering if something is meant to be poking through that hole.
Possibly something to do with ABS.
Posted: Thu Oct 27, 2011 10:12 am |
See if you can find some numbers on the wires somewhere.
Posted: Thu Oct 27, 2011 10:17 am |
OH! fog lights?! some models have the wiring but not the actual light units on the bumper
Posted: Thu Oct 27, 2011 10:19 am |
There is no numbers on the wire itself.
The socket has a number on it, but I think its a part number.
It reads... >PBTP QF 30<
After looking about, its the exact same socket that is connected to the indicator.
The car has no fog lights, so could be that!
But wouldn't it be strapped up? or at least have a cover over the socket!
Posted: Thu Oct 27, 2011 10:24 am |
Cal91 wrote: |
But wouldn't it be strapped up? or at least have a cover over the socket! |
remember its peugeot you're talking about here
Posted: Thu Oct 27, 2011 10:26 am |
Antknee wrote: |
remember its peugeot you're talking about here  |
The car isn't actually mine, its my mums. I drive a Vauxhall Astra... a bit different to the 206, I must say!
Antknee wrote: |
Cal91 wrote: |
This.
Posted: Thu Oct 27, 2011 1:16 pm |
Wrong. I stumbled across this wire today and I have fogs. Its the same figment as the indicator. I also have a H4 plug under my headlamp
Posted: Thu Oct 27, 2011 1:26 pm |
Ooo, ooo, can i have a wild stab in the dark too??? Erm... Autolights.
Yeah, thats it.
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport  | |
Posted: Thu Oct 27, 2011 1:43 pm |
The sidelight uses a plug like that.
Posted: Thu Oct 27, 2011 3:17 pm |
Howey wrote: |
Yeah, thats it. |
Autolights only add's a plug for the rain / light sensor inside the car, doesnt add anything under the bonnet.
