Online Now [238]:
Visitors: 237
Today: 45572
Total: 142314050
Forums › The Car › 206 Problems › MOT Fail.
MOT Fail.
devildriverxii
PostPosted: Fri Oct 28, 2011 4:58 am Up
On:
Rear fog lamp tell tale not working. [Fixed - Bulb/Fuse]
Offside rear fog lamp not working. [Fixed - Fuse]
offside headlamp not working on dipped beam. [Fixed - Bulb]
Offside headlamp insecure [Fixed - 3 of 6 bolts missing Confused ]
Nearside headlamp aim too low.
(fuel tank) fuel system component leaking [Fixed - Perished seal]
and a balding rear tyre.
So apart from the fuel tank, are these easily fixable. I would have asked someone at kwik-fit, but it seemed like they just wanted me out.
Hopefully they are all things I can do myself.
Thanks for any help.
2002 1.6 5dr Black Edition.
Mrs_Howey
PostPosted: Fri Oct 28, 2011 5:03 am Up
Well sounds like the top 3 are bulbs,
Headlight are all the bolt there and tight??
And the headlight aiming low, they should re-adjust that for you
And you need a new rear tyre
Smile Doesn't sound to bad
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
iainlovatt
PostPosted: Fri Oct 28, 2011 5:05 am Up
tell tail means that the fog light isnt lighting up on the speedo is that correct?
others could be a few bulbs doesn't sound to me like you even bothered doing a pre mot test before taking it to them!
(My Garage)
pug206lx
PostPosted: Fri Oct 28, 2011 5:20 am Up
Yep
devildriverxii
PostPosted: Fri Oct 28, 2011 5:51 am Up
Actually I did. I ordered a whole new set of bulbs...which were on my door step when I got back after failing, partly from me leaving it a day too long before ordering, but all my lights worked until last night when my offside headlight stopped working, which I told them as I haded my keys over.
I did forget about my rear fog though =(
And I changed all the bulbs in my speedo not a week ago (see my many threads about bulbs Razz ) that one must have been a dud.
iainlovatt
PostPosted: Fri Oct 28, 2011 6:30 am Up
sounds like it, just put all the bulbs in and check everything, should be ok then!
(My Garage)
PostPosted: Fri Oct 28, 2011 6:53 am Up
On:
Offside headlamp insecure.
(fuel tank) fuel system component leaking.
What sort of car are you on about?
A 206 only has 1 rear fog lamp, and that's in the centre of the rear bumper.
A Kwik Fit MOT...enough said really.
devildriverxii
PostPosted: Fri Oct 28, 2011 10:31 am Up
On:
Yeah it says
002 Offside rear Rear fog lamp not working [1.3.2b]
Also, I changed the bulb in the speedo for the rear fog...but I swear I've never had that light work? I assumed as the rear fog comes on with the front fogs there was no need for 2 lights...strange.
Also, I have a clear smoked fog light, does the bulb I put in it have to be red? or can I just use a clear bulb?
paul_c
PostPosted: Fri Oct 28, 2011 10:41 am Up
With the fog light and its tell tale not working, it might not just be a case of changing the bulb, it looks like a more serious electrical problem. Did it work before you changed it to a clear smoked one? Did you test it after you changed it?
Mrs_Howey
PostPosted: Fri Oct 28, 2011 10:52 am Up
On:
Yeah it says
pretty sure you will need a red bulb
pro race 1.2 White
Morettes
GTI wings
-Dave-
PostPosted: Fri Oct 28, 2011 2:09 pm Up
Trade Rating: +36
Bulbs and tyres are the easiest thing to check before a mot. I'm shocked they are even on the fail list as these should be things that are checked regularly. I know you said you ordered them but I would have thought it would have been best to book the mot after you received them. If the fuel system was ok just by changing them you could have saved yourself the hassle of a retest. And I'm even more shocked they didn't just quickly adjust the headlight for you. Every mot station I have used in the past would have done this automatically.
Ex 206 Owner.
PostPosted: Fri Oct 28, 2011 2:46 pm Up
Check the earth on the rear fog light Wink
Matt
PostPosted: Fri Oct 28, 2011 3:24 pm Up
Trade Rating: +32
Middle Earth or 3rd Earth?
devildriverxii
PostPosted: Fri Oct 28, 2011 4:24 pm Up
I'm 99.998% sure that the rear fog light tell tale has never worked on my car Confused Anyway, It worked before I changed it, and after.
devildriverxii
PostPosted: Sat Oct 29, 2011 10:43 am Up
Thinking about it, it might be a blown fuse, cause when my ppt40 burned out a few months ago, the display on my aircon unit went too, though the buttons still light up, the display doesnt.
Anyone know which set of fuses to check, or should I just check them all?
Does the BSI contain fuses?
