Latest: tbafonso
Overall: 17130
Online Now [463]:
Visitors: 463
Today: 60600
Total: 104111266
Forums › The Car › 206 Talk › Decision on a not working air.con
Gary41
PostPosted: Sat Oct 29, 2011 9:02 am Up
Hi my aircon dosent work at all nothing happens when i push the button in the idle dosent drop ,the pulley is not seized
I dont want to fork out for a re gas incase that dont fix it any ideas
Also is it worth taking of and putting a smaller belt on would there be much power gain or is best just left
Cheers for any advise
Mrs_Howey
PostPosted: Sat Oct 29, 2011 9:45 am Up
If you take it to a company which does air con, they can service they system and tell you why it doesn't work. Most of the time it's because it's run out of gas. So when you push the button nothing happens to stop the compressor from breaking Smile
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
paul_c
PostPosted: Sat Oct 29, 2011 11:31 am Up
There's no gain to physically removing components because the compressor has a clutch.
Also, as above, get it checked out. Re-gassing air con should be done regularly anyway, and the fault could be something as simple as a blown fuse.
PostPosted: Sat Oct 29, 2011 11:32 am Up
Will need regassing.
The A/C ECU is clever you see Wink
Gary41
PostPosted: Sat Oct 29, 2011 11:46 am Up
Thanks for the advise if fuse is ok il get it gased cheers
Gti
PostPosted: Sat Oct 29, 2011 11:51 am Up
Fuse will be ok, needs gas
jordey-hdi
PostPosted: Sun Oct 30, 2011 8:29 am Up
The compressor clutch won't kick in if there is lack of gas because the pressure sensors on the system won't let it damage the compressor, regas it jobs a goodun, unless there's a leak but you can have it checked as said above
...jordey
Horsepower wins arguments.......torque wins races
