Latest: tbafonso
Overall: 17130
Online Now [54]:
Visitors: 54
Today: 9343
Total: 104134141
Forums › The Car › 206 Problems › 206 started to overheat and loose water......
ldare2000
PostPosted: Sun Oct 30, 2011 1:25 pm Up
Hi,
I am worried that my 206 maybe about to develop an overheating fault.
Ive notice is starting to use/loose coolant and have to top up quite a small ammount each weekend and now in traffic it'll reach the notch after 90 and the fan kicks in and the temp comes down.
I had the water pump changed in the summer when the belts were done. Are there any simple tests I can do myself before going to the garage?
Louis
Lou
PostPosted: Sun Oct 30, 2011 1:29 pm Up
Headgasket im feeling or a small leak
Any white s**te under the oil cap? Any white smoke from the exhaust when warmish?
ronnie
PostPosted: Sun Oct 30, 2011 3:16 pm Up
where can the coolant be going?
Only 2 places it can go
1/ a leak........look under the car and also the front carpet area to see signs of water
or
2/ head gasket failure.......your car will be burning the water and exhaust fumes will be white
check condition of oil just incase it is being mixed.
All the best
Ronnie
ronnie
ronnie
PostPosted: Sun Oct 30, 2011 3:20 pm Up
Meant to ad
Bubbles in the expansion water bottle indicate a blown head gasket
A sniff test at a garage will tell you for sure if it is the head gasket.
Ronnie
ronnie
st200ant
PostPosted: Sun Oct 30, 2011 3:27 pm Up
Head gasket mate
ldare2000
PostPosted: Wed Nov 02, 2011 3:43 pm Up
Hi,
I think exhaust is whiter than normal and coolant looks quite dirty.
Should I buy one of these and test www.ebay.co.uk/itm/PET...680wt_1030
How much should I expect to pay for a good head gasket replacement?
Louis
Lou
ldare2000
PostPosted: Fri Nov 04, 2011 2:39 pm Up
Hi,
Strangly main dealer repairseems cheapest option, quoted me 300 if easy change and if skim not needed. Had prices of upto 500 from smaller local garages.
I can afford to do this just yet. When I drive car sits at 80-85 degree. When in traffic rises untilfan kicks in. I read that if you short the wires where the sensor meets the radiator the fan will come on..... But I can't see a sensor on the radiator. Anywhere else I can short to bring the fan on?
Lou
deanparkr
PostPosted: Fri Nov 04, 2011 3:11 pm Up
A main dealer qouted just £300 for a head gasket? Wow!
2002 1.4LX
PostPosted: Fri Nov 04, 2011 5:24 pm Up
without skimming it is pointless to do headgasket
sx206
PostPosted: Sat Nov 05, 2011 2:03 am Up
skimming is only needed if the cylinder head is warped.
206
ldare2000
PostPosted: Sat Nov 05, 2011 2:34 am Up
Yeah 300 if head is not warped, I am guessing their high hourly rate is out weighed by them having done the job many times and now quite quick at doing.
No white muck in my oil, never overheated into the red. The fan kicks in just in time, however if I can work out how I'd like the start the fan myself earlier than 95-100 degrees
Lou
Dutch-HDi
PostPosted: Sat Nov 05, 2011 5:19 am Up
it’s delaying the inevitable, the big white cloud, just get it done before it costs a lot more $$$$s
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
Ali_H
PostPosted: Sat Nov 05, 2011 5:49 am Up
Bodging it really won't help.
kurtis wrote:
ldare2000
PostPosted: Fri Nov 11, 2011 1:48 pm Up
Yeah done a compression test 13,12,9,13 bar so dropped off at local Peugeot garage..
Fingers crossed the head is not warped, they said they dont warp always.
Lou
