Posted: Thu Nov 03, 2011 5:51 am |
What do i do with everything below the red line when fitting an induction kit? Its in the way of the cold air feed. Also it seems pretty pointless just sat there disconnected. thanks
Posted: Thu Nov 03, 2011 5:52 am |
I have already removed the airbox etc just wondering what i do with the remaining.
Posted: Thu Nov 03, 2011 5:54 am |
You can remove it, it's not very hard to do part 5 goes behind the wing and just pulls out and iirc part 7 is just a bolt or 2 to remove. Weight saving
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Posted: Thu Nov 03, 2011 6:16 am |
so it what is it lol. sorry Ive never seen anything like it before. Thanks for your help
Posted: Thu Nov 03, 2011 6:18 am |
It's the secondary air pump, normally throws up a fault code in the ECU when you remove it.
Posted: Thu Nov 03, 2011 6:27 am |
so id it worth removing it then? just hangs at the moment?
Posted: Thu Nov 03, 2011 7:29 am |
so what can i remove without throwing up faults?
Posted: Thu Nov 03, 2011 7:56 am |
Just take the air box out and leave the rest there.
