Online Now [523]:
Visitors: 522
Today: 25540
Total: 106219767
Forums › The Car › 206 Talk › Hdi Injectors - An afternoons Tinkering !
Dutch-HDi
PostPosted: Fri Nov 04, 2011 3:00 pm Up
Well i finally decided to trace the problems of a slightly erratic tick over, figured that had to be the injectors, but how to check if it’s one or all four of them at home?
Firstly i decided to see if there was a problem with the injectors ohms resistance I'm not sure of the correct resistance reading needed but looked for any big difference’s, I got the following readings
(#1), 1.2 (#2) 1.3 (#3) 1.2 (#4) 1.3
figure that those are close enough to each other to be ok
Well got 4 bottles and 4 equal lengths of clear tubing drilled the tops so the tubes went in and gave me a fuel return volume reading, now disconnected the fuel leak off pipes from the injectors and connected it all up. Looked kind of funny but all looked tight and leak proof so started it up for 2 min’s on tick over and measured the fuel returned.
from my way of thinking the injector that returns the least amount of fuel is the one/s that are not or least blocked ( didn’t get ml measurements) but 1,3,4 return was high and #2 considerably lower marked with felt pen to compare later.
Has to be blocked or gummed injectors that got me thinking and had a quick look online for a diesel specialist nearby for ultrasonic cleaning, only found 1 that dealt with sending away I really wanted to have service exchange or clean and refit while you wait service, and looking at the business address was a private house Shocked not a business premises so that’s a no go IMO
Determined not to be put off looked in ultra-sonic machines and found one that just suited what i wanted and just large enough for 1 injector at a time and a good price, happy days!
Tested the sonic cleaner on a few old spanners woohoo, worked a treat so outcome the injectors dropped in the solution and 60c and left them on a cycle for 2x 8 min’s each
The crap and crud was unbelievable that came off each injector but in my haste forgot about new injector sealing washers before refitting, so cleaned them up and annealed them with a trusty blow lamp the inspected them looked A1
Refitted injectors connectors and return fuel lines and connected harness and charged the system paranoid to find leaks but had non result, Fired her up after a few fuel pump charges, then fairy liquid and water from a spray bottle to check for injector blow by and still paranoid looking for bubbles everywhere, phew got non, tick over now seams steady as a rock around 780 without anyfluctuations, The test drive feels so much more responsive and instant quicker throttle response Wink
A quick look under the bonnet hooked up the fuel return gizmo to the fuel returns and gave her another few min’s on tick over then checked the returned fuel for each injector, all very similar returns form each and a little less than the first checks comparing the two, connected everything back and closed the bonnet happy with an afternoons tinkering
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
Antknee
PostPosted: Fri Nov 04, 2011 3:34 pm Up
sounds like a job well done, nice one
jordey-hdi
PostPosted: Fri Nov 04, 2011 4:53 pm Up
Should make a 'how to' lol, il be getting my injectors done before it goes on the road;)
...jordey
Horsepower wins arguments.......torque wins races
Dutch-HDi
PostPosted: Sat Nov 05, 2011 5:12 am Up
Did think about it, but only got a few pic's, before the battery went half way through oily hands and missus not wanting me searching the house in dirty jeans, also wasnt sure how far i was gonna go before finding the problem, i'll get a few pics up and then take a few more later today Thumb Up
mjsroofing
PostPosted: Sun Nov 06, 2011 6:28 am Up
so what ceaning machine did you get and were from, how much did it cost???
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
Dutch-HDi
PostPosted: Tue Nov 08, 2011 9:03 am Up
Used this machine from maplins, cost £99. Works fantastic although there is cheaper avalible wanted a better machine Very Happy
