Online Now [68]:
Visitors: 67
Today: 44380
Total: 105307675
Forums › The Car › 206 Problems › Peugeot locking nut key
Andrew
PostPosted: Fri Nov 04, 2011 12:17 pm Up
Ok so I've lost my locking nut key, I'm sure my friend has it but I won't be able to check with him for a while
I've found a place on ebay that sells replacement ones, but you need to know a code stamped on the key which is a number between 1 and 30. My locking bolts have the 4 pins positioned in a perfect square, so I'm hoping someone has similar ones and could tell me their code
I know its a very long shot but worth a try Sad
My 206 thread
www.detailedbyandrew.com
Antknee
PostPosted: Fri Nov 04, 2011 12:21 pm Up
spray some cooking oil on it and push in some blutac to get an impression then shop around comparing Razz
PostPosted: Fri Nov 04, 2011 12:28 pm Up
I can get you the code if it's the original. pm me
dan1231123
PostPosted: Fri Nov 04, 2011 1:24 pm Up
hi my locking wheel key sheared and was unsuseable , so i took it to a tyre fitter and i got them to take them off for me just with a socket and alot of hammering , it cost me £15 to get all four locking bolts off tho
hi to all
Andrew
PostPosted: Fri Nov 04, 2011 1:35 pm Up
I would use a socket straight away but I don't have any bolts to replace these with if they get wrecked
I've asked the seller to send me one with the pins in a square position, failing that just send me number '1' so I can do some bodging to make it work, as long as one or two of the pins fit in I should be ok
My 206 thread
kingsway2468
PostPosted: Fri Nov 04, 2011 2:06 pm Up
All locking nuts are diffrent so unless you get your code you will not get it off so its eva use hammer qnd sockett or you can get this kit wich you screw on to the lockin nut it has left hand thread so when it gets tight it loosens the nut
Andrew
PostPosted: Sat Nov 05, 2011 10:16 am Up
I may have to resort to this Sad
My 206 thread
Dutch-HDi
PostPosted: Sat Nov 05, 2011 10:18 am Up
I got two diffrent 1's you could try mate if your stuck b4 resorting to a big hammer and socket Shocked
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
Andrew
PostPosted: Sun Nov 06, 2011 9:21 am Up
Thanks for coming over and having a try Steve, unfortunately his keys weren't quite the same as mine Sad
I'm going to try a local Peugeot breakers tomorrow to see if they have any keys
My only other idea is that if somebody who has a key with the 4 prongs in a perfect square pattern, could tell me their VIN so Lee would be able to find the code for the replacement I could buy
My 206 thread
PostPosted: Sun Nov 06, 2011 9:31 am Up
Just hammer them off, then go out tomorrow and buy a new set of locking wheel nuts. At least that way you will have a key that fits them.
It's probably as cheap to buy a set of bolts as it is to get a replacement key, and a hell of a lot easier.
Why would they need to give you the VIN if the number is stamped on the key?
Andrew
PostPosted: Sun Nov 06, 2011 9:38 am Up
That way even if they were dumb enough like me to have misplaced their key, we would still have some information to go from, but yeah the key code in the first place would be good.
A replacement key is £7 delivered and a new set of bolts and key would be around £40
As I say I'm visiting a peugeot breakers I know tomorrow, they should be able to help me out
My 206 thread
PostPosted: Sun Nov 06, 2011 10:19 am Up
Just pay a tyre garage to remove the Peugeot locking bolts, there total s**te & not worth buying a new key for.
Replace them with McGard's.
