Posted: Sun Nov 06, 2011 5:22 pm |
lost me haynes manual need to know so i can torque up the head bolts on a 1.6 8v
Posted: Sun Nov 06, 2011 5:27 pm |
Is it a cast iron or aluminum block. Got Haynes page in front of me
Posted: Sun Nov 06, 2011 5:28 pm |
no idea, by the weight i would guess iron but unsure
Posted: Sun Nov 06, 2011 5:31 pm |
Sent you a message on FB with torque settings attached
Posted: Sun Nov 06, 2011 5:43 pm |
Don't forget that they are stretch bolts. They should be a maximum of 176.5 mm (underside of head to bolt tip). Any longer and you should replace all 10.
Some people would suggest you replace the bolts as a matter of course.
Posted: Sun Nov 06, 2011 5:52 pm |
Yer there all new bolts, come with gasket as a deal. Thanks
Posted: Sun Nov 06, 2011 6:26 pm |
You should have the torque settings and sequence with the head gasket
Posted: Sun Nov 06, 2011 6:38 pm |
think all 8v block are cast iron
Posted: Mon Nov 07, 2011 3:24 am |
No settings with gasket packaging kingsway.
And cheers seabrook , going by the weight I thought it might be could only just lift it off the floor
On my own.
