Latest: tebas93089
Overall: 17179
Online Now [134]:
Visitors: 134
Today: 7339
Total: 138373378
Forums › The Car › 206 Problems › clunking from nearside front
longeatonlad
PostPosted: Mon Oct 24, 2011 11:30 pm Up
there's a 'clunking' noise coming from the nearside front. if i come to speedbump, go to the right so the n/s/f wheel goes over the bump you can hear it clunk, hi the bump with the o/s/f wheel, no clunk.
ive not had chance to have a proper look yet, but im guessing either track rod, droplink or worn bush of somesort?
206 gti 180 Wink
kingsway2468
PostPosted: Tue Oct 25, 2011 2:03 am Up
Check wishbone bushes if it id change the whole wishbone not much more expensive
d roth
longeatonlad
PostPosted: Thu Oct 27, 2011 2:19 am Up
cheers, ive yet to to look, i was going to yesterday but a 18 hour day and trip to scotland ruined that lol.
206 gti 180 Wink
Skullion
PostPosted: Thu Oct 27, 2011 3:29 am Up
Scotland isnt that bad to ruin your mate Razz lol
Pug 206
longeatonlad
PostPosted: Thu Oct 27, 2011 5:34 am Up
every time i go its raining and everytime i forget to take a waterproof coat lol
206 gti 180 Wink
Dutch-HDi
PostPosted: Thu Oct 27, 2011 5:45 am Up
ive got a kagool tucked away in the boot where the wheel brace fits Wink
I travel there quite regularly to, just need to find somewhere to hide my wellies Laughing
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
longeatonlad
PostPosted: Sat Nov 05, 2011 5:20 am Up
right...
anti roll bar bushes, wishbone bushes, droplinks, balljoints, top mounts all absolutely fine.
the only other thing i can think of is the shocker itself?
edit, track rods ok too!
206 gti 180 Wink
Dutch-HDi
PostPosted: Sat Nov 05, 2011 5:32 am Up
had a look at the engine mounts? ideas are getting thin now unless it is the shocker
longeatonlad
PostPosted: Sat Nov 05, 2011 6:49 pm Up
knew there was something i missed off the list! yes, all mounts seem ok too.
206 gti 180 Wink
kit325
PostPosted: Tue Nov 08, 2011 11:35 am Up
Double check your anti roll bar link by remove it completely from the suspension, check the stiffness of both of the arb link ball joint. It will cuase clunking problem if one of the ball joint is loose (usually the one link to anti roll bar) and another ball joint is stiff.
If the ruber seal is till in good condition u can solve the clunking problem by installing the loose section to the strut and stiff section to the bottom on both sides.
Would cost u a penny by doing this, just need some time. Worth a try, it works for me.
kit
gazza82
PostPosted: Tue Nov 08, 2011 11:57 am Up
Aren't the top shock mount bearings prone to failing and clocking too?
sx206
PostPosted: Tue Nov 08, 2011 2:03 pm Up
i think you will soon find out everything is prone to failing on these s**te boxes. Idea
206
mjrimmer
PostPosted: Tue Nov 08, 2011 3:09 pm Up
I had the same problem. It would knock going over bumps and if off the throttle on a cobbled street you thought the car was going to fall to bits, it would also knock under hard acceleration when changing from 1st to 2nd gear.
Everything looked fine until i got it on a ramp at my local garage.
On the ramps it was easier to check the condition of the wishbones and compare one side to the other....mine turned out to be the front inner bush. It didn't look too bad on the car but when I changed the wishbone and inspected it off the car there was loads of play in it. My drivers side is just starting to knock slightly now so that'll get done within the next week or so.
Europarts sell the replacement wishbone bushes (lemforder) if you have a press, else it's just easier to change the whole wishbone.
206 gti 180
