Posted: Mon Nov 14, 2011 2:24 am |
I have a 2001 GTI 206 coupe, 2 litre.
The backlights on my heater/ac unit and dash clock/temp guage wont work. I have replaced the LED's, but no win.
All fuses are fine, and heaters working fine. I can see the clock and stuff working when i shine a torch on it, but with no back lighting it cant be seen any other time.
Any ideas?
Thanks!
Adam.
| Im from New Zealand. The land of not many Puegeots... | |
Posted: Mon Nov 14, 2011 3:18 am |
Make sure you've got got connections with the plugs, if you have a multimeter you can test to see if your getting power, if you aren't the LED's may not be making contact properly. I had this problem with my clock and had to bend the contacts downwards
| You never really learn to swear until you learn to drive | |
Posted: Mon Nov 14, 2011 3:38 am |
I have this problem but only with my digital air conditioning, most of the time its off, but randomly it will turn all the lights on at night
I assume loose connection somewhere i've yet to take it apart and look
Posted: Mon Nov 14, 2011 11:12 am |
Cool thanks yeah i'll check all the connections and post of my progress
Posted: Mon Nov 14, 2011 11:14 am |
if its LED's your using they only work one way round. take them out, turn then half way round and put back in. see what happens.
Posted: Tue Nov 15, 2011 2:17 am |
Are LED's polarity sensitive? If they are backwards, no good?
Posted: Tue Nov 15, 2011 10:26 am |
| dori wrote: |
| Are LED's polarity sensitive? |
YES they are!
Led's will only work if there fitted the correct way round
