Latest: tbafonso
Overall: 17130
Online Now [829]:
Visitors: 828
Today: 107321
Total: 102683224
Forums › The Car › 206 Problems › heater blower/climate control
stevepengilly
PostPosted: Sat Oct 08, 2011 6:38 am Up
Blower/Motor Will Stop Going...Then Start Up Again By Itself...Dont Think It Actually Stops Can Hear It A Tad...And A Wee Squealing Noise When It Stops Blowing, it works when car is started but gets lairy whilst driving!
any ideas folks
this is a x reg GTI with climate control....new to Pug world! :-/
LIVE LIFE FAST!
View user's profile Visit poster's website AIM Address MSN Messenger Yahoo Messenger
A18NHH
PostPosted: Sat Oct 08, 2011 6:42 am Up
thnk you need to replace the heater blower motor - had a similar problem on my 2002 GTi, bought a replacement motor and fitted it myself and never had a problem since
Wahoo!
paul_c
PostPosted: Sat Oct 08, 2011 6:47 am Up
A drop fo WD40 will probably cure the squeak. Stopping and starting of the motor is normal for climate control, you can control the fan to blow at a fixed speed if you want though.
PostPosted: Sat Oct 08, 2011 7:46 am Up
Definately needs a new fan. Mine behaved in an identical manner. Buying a new fan solved the problem. No point getting a 2nd hand fan. Fan is specific to cars with climate control.
www.aepdirect.com/heat...ry_id=3367
A18NHH
PostPosted: Sat Oct 08, 2011 10:23 am Up
i found a fan from anoother 206 GTi with climate control - 2nd hand pair £25 and like i say still have no problems with it now
Wahoo!
ronnie
PostPosted: Mon Oct 24, 2011 2:51 pm Up
is this the same blower motor for a Y-reg 206cc 2.0ltr
I think I have the same problem as original poster
Is the blower motor controled by a + and - buttom?
Our 1.6 206cc has a switch so it is a bit different
Did you ever get it sorted?
ronnie
ronnie
PostPosted: Thu Oct 27, 2011 9:31 am Up
It is the blower motor resistor
Just sorted mine with a brand new resistor from e-bay £40
It is from a 307 but it works fine.
30 minute job to remove the motor unit ,replace the resistor and then install back in the car.
Remove glove box and housing with 7 torx screws and then twist off the blower unit complete.
Hardest part was pressing off the blower fan cage as I was worried it would break.
Easy fix.
Hope this helps others
Ronnie
ronnie
PostPosted: Thu Oct 27, 2011 12:19 pm Up
No it's not because the cars with climate control don't have a resistor for the fan.
ronnie
PostPosted: Thu Oct 27, 2011 1:01 pm Up
HEATER BLOWER MOTOR RESISTOR FOR XSARA PICASSO 307 206 AIRCON MODEL CLIMATE
www.ebay.co.uk/itm/HEA...5646307147
What is this
Ronnie
ronnie
djaydearz
PostPosted: Mon Nov 14, 2011 11:19 am Up
Hi all, sorry for the bump thread
I have a 2002, 206 1.4lx
My fan only works on setting 4, looking into other posts, it seems to be the motor or more probable, the resistor iteself.
My problem is that i can't for the life of me work out how to remove the blower motor. People say just turn it clockwise/anticlockwise (mixed instructions there) but i can't get it to budge the slightest
(I have removed the 1 screw in it) but its so awkward i can barely get my hands in the gaps!)
Regards
J
shamone
