Latest: KevinRC
Overall: 17137
Online Now [205]:
Visitors: 204
Today: 101594
Total: 111136053
Forums › The Car › 206 Problems › Lights on heater and console unit not working
dori
PostPosted: Mon Nov 14, 2011 2:24 am Up
I have a 2001 GTI 206 coupe, 2 litre.
The backlights on my heater/ac unit and dash clock/temp guage wont work. I have replaced the LED's, but no win.
All fuses are fine, and heaters working fine. I can see the clock and stuff working when i shine a torch on it, but with no back lighting it cant be seen any other time.
Any ideas?
Thanks!
Adam.
Im from New Zealand. The land of not many Puegeots...
ukskater01
PostPosted: Mon Nov 14, 2011 3:18 am Up
Make sure you've got got connections with the plugs, if you have a multimeter you can test to see if your getting power, if you aren't the LED's may not be making contact properly. I had this problem with my clock and had to bend the contacts downwards
ramigojag
PostPosted: Mon Nov 14, 2011 3:38 am Up
I have this problem but only with my digital air conditioning, most of the time its off, but randomly it will turn all the lights on at night
I assume loose connection somewhere i've yet to take it apart and look
dori
PostPosted: Mon Nov 14, 2011 11:12 am Up
Cool thanks yeah i'll check all the connections and post of my progress
PostPosted: Mon Nov 14, 2011 11:14 am Up
if its LED's your using they only work one way round. take them out, turn then half way round and put back in. see what happens.
dori
PostPosted: Tue Nov 15, 2011 2:17 am Up
Are LED's polarity sensitive? If they are backwards, no good?
PostPosted: Tue Nov 15, 2011 10:26 am Up
YES they are!
Led's will only work if there fitted the correct way round Wink
