Latest: ArtistKS
Overall: 17145
Online Now [172]:
Visitors: 171
Today: 5054
Total: 116061996
Forums › The Car › 206 Talk › idea of cost for new bsi unit ???
Go to page Previous  1, 2
broadblaster
PostPosted: Thu Nov 17, 2011 4:50 pm Up
ok lee thanks for the heads up if no voltage what would that say to me as said it will lock fine on the fob but not unlock he had all the wireing out from the doors incase a wire was broken in the bit between the door and main body and all was ok
on a back road playing
PostPosted: Thu Nov 17, 2011 4:54 pm Up
If there is no voltage, then it is the BSI
But you should be checking it with the laptop, and not the fob really
broadblaster
PostPosted: Thu Nov 17, 2011 5:00 pm Up
ok thanks for you help it is really appreciated i will ask him to check that as said when i tryed my mates scanner (not sure on make) it would read all the system what type and all the model and serial numbers and let me run tests and it would lock fine just not unlock via the system
i have seen the bouncing lock problem before but never a unlock problem lol lol
PostPosted: Thu Nov 17, 2011 5:03 pm Up
I wouldn't get a new BSI anyway.
Buy Harry's BSI and get your IMMO coding copied over, will be a lot less
broadblaster
PostPosted: Thu Nov 17, 2011 5:07 pm Up
i see what you are saying mate but i'm sort of thinking if i go new it would come with a warrenty and as i intend to keep the car now it may not be a bad thing to have also nobody i know has PP down this way that i know to code it all in for me
PostPosted: Fri Nov 18, 2011 9:52 am Up
Warranty ONLY if a Peugeot main dealer fits & codes it Wink
broadblaster
PostPosted: Fri Nov 18, 2011 12:48 pm Up
thats what i was thinking of doing mate, but i did speak to the man at bba remans (the site/co you gave me a link for) and he seems very helpfull and recons it would be around 150 to have my unit checked out and sorted, also comes with 2 yr warrenty on there work. he has said that it would not need recodeing or programed to the car as its the original unit unless it needs to be virginised (which he recons is rare).
so i may go down that route.
just trying to work out the best option for me atm as i could also do away with the factory central locking and alarm and fit a good quality aftermarket (toad/clifford) set up to the car which would also give me central locking, its a job to know whats best to do as evrything else works fine with the bsi.
PostPosted: Fri Nov 18, 2011 1:09 pm Up
Id let BBA have a look at / repair it, cars gonna be unusable while BSI is removed.
broadblaster
PostPosted: Fri Nov 18, 2011 1:16 pm Up
yeah they say that aound 4 days is normal turn around time, so not to bad as i have others i can use.
the only thing that puts me off a bit is if they do have to virgin the unit i will then have to pay to get it reprogramed in. and then that will take me to the same sort of costs as it would to have a new alarm/central locking fitted and i can have that done in a morning right next door to where i work.
Page 2 of 2
