Posted: Thu Nov 17, 2011 2:59 pm |
any ideas of cost for a new bsi unit and to have it programed in to my car ??????? gti 180 04
thanks
Posted: Thu Nov 17, 2011 3:04 pm |
Trade Rating: +31
600-700 squidz.
Posted: Thu Nov 17, 2011 3:09 pm |
hmm may have to have a check about and see if i can get one from a ecu place and then get it programed by pugs
Posted: Thu Nov 17, 2011 3:47 pm |
What's the problem?
Posted: Thu Nov 17, 2011 3:48 pm |
Someone on the 206GTi180 FB group just paid £580 fitted.
Posted: Thu Nov 17, 2011 4:22 pm |
my central locking is still not working lee
had a sparks who i trust look at it today and he has checked all the wireing and the door solanoids and all seems to be ok so it looks like the bsi is not working as it should.
Posted: Thu Nov 17, 2011 4:24 pm |
cheers ali looks like it gonna get costly
Posted: Thu Nov 17, 2011 4:25 pm |
He tried locking the doors via the BSI?
Posted: Thu Nov 17, 2011 4:28 pm |
tbh mate i was'not there but he assures me all is ok with everything he could test which only leaves the bsi
Posted: Thu Nov 17, 2011 4:29 pm |
Does it work with the key in the lock?
Posted: Thu Nov 17, 2011 4:30 pm |
just to add i used a mates scan tool and the doors would not unlock on his scanner but would lock
Posted: Thu Nov 17, 2011 4:31 pm |
| Lee wrote: |
| Does it work with the key in the lock? |
only the door you use the key on will open it locks all doors on the fob but will not unlock any
Posted: Thu Nov 17, 2011 4:42 pm |
check white wire (620), pin 15 in grey plug on bsi
Posted: Thu Nov 17, 2011 4:44 pm |
is that check it as in it may be loose or disconected mate ????
Posted: Thu Nov 17, 2011 4:47 pm |
That there is voltage when you unlock the car
