Latest: tbafonso
Overall: 17130
Online Now [58]:
Visitors: 58
Today: 14223
Total: 104139012
Forums › The Car › 206 Problems › Gti drivers seat
Gti drivers seat
JonnyGTI
PostPosted: Sat Nov 19, 2011 5:50 am Up
I'm having a problem with the drivers seat the full seat will move forward and back for the legs to fit on but the problem is with the back part
It won't tilt forward or recline so I'm in a position I'm not comfortable in
Would anyone be able to advice on what it could possible be and if it's an easy fix or a garage job
It's the lever type not windy type and it's a 99 plate 206 gti
Cheers jonny
kirsteyjames
PostPosted: Sat Nov 19, 2011 6:11 am Up
Try taking the lever off, there's one torx screw holding each side on. I had this problem before, the plastic on the lever had cracked on the inside so it wasn't turning the metal rod thing fully. Use a pliers to turn the metal rod and see if your seat moves Smile
