Posted: Sat Nov 19, 2011 5:21 pm |
dont wanna sound dumb but is it safe to run the 206 with the purge valve vacume pipe disconnected?
| | ![](images/spacer.gif) |
| if it dont scuff the ruff it aint low enuf | |
Posted: Sat Nov 19, 2011 5:58 pm |
Purgee valve vaccuum pipe?
Posted: Sun Nov 20, 2011 4:11 am |
Danw_VVT wrote: |
Purgee valve vaccuum pipe? |
Quote:: |
Gasoline evaporates quite easily. In the past, these evaporative emissions were vented into the atmosphere. 20% of all HC emissions from the automobile are from the gas tank. In 1970 legislation was passed, prohibiting venting of gas tank fumes into the atmosphere. An evaporative control system was developed to eliminate this source of pollution. The function of the fuel evaporative control system is to trap and store evaporative emissions from the gas tank and carburetor. A charcoal canister is used to trap the fuel vapors. The fuel vapors adhere to the charcoal, until the engine is started, and engine vacuum can be used to draw the vapors into the engine, so that they can be burned along with the fuel/air mixture. This system requires the use of a sealed gas tank filler cap. This cap is so important to the operation of the system, that a test of the cap is now being integrated into many state emission inspection programs. Pre-1970 cars released fuel vapors into the atmosphere through the use of a vented gas cap. Today with the use of sealed caps, redesigned gas tanks are used. The tank has to have the space for the vapors to collect so that they can then be vented to the charcoal canister. A purge valve is used to control the vapor flow into the engine. The purge valve is operated by engine vacuum. One common problem with this system is that the purge valve goes bad and engine vacuum draws fuel directly into the intake system. This enriches the fuel mixture and will foul the spark plugs. Most charcoal canisters have a filter that should be replaced periodically. This system should be checked when fuel mileage drops. |
Posted: Sun Nov 20, 2011 4:40 am |
so can i run my car with the hose disconnected from the valve?
Posted: Sun Nov 20, 2011 4:46 am |
dumdum0910 wrote: |
so can i run my car with the hose disconnected from the valve? |
Is this for testing purposes or?
Posted: Sun Nov 20, 2011 4:52 am |
so i can drive about 3 miles to get to my old mans place
Posted: Sun Nov 20, 2011 4:55 am |
dumdum0910 wrote: |
so i can drive about 3 miles to get to my old mans place |
Try it and see how the car runs. I would think its better to block the pipe manualy after a couple of minutes from start-up, and see.
Someone might have a better idea.
Posted: Sun Nov 20, 2011 6:14 am |
I'd like to remove mine. It's not connected to the inlet in any way.
