Latest: tbafonso
Overall: 17130
Online Now [176]:
Visitors: 175
Today: 31954
Total: 102554729
Forums › The Car › Request a how-to › How do you take off the airbag cover on the dashboard?
Forum IndexRequest a how-to
BigGreenDave
PostPosted: Tue Nov 22, 2011 9:18 am Reply with quote Up
How!?!?
F**k Scene YAWN
PostPosted: Tue Nov 22, 2011 9:22 am Reply with quote Up
as in to replace air bag?
take glovebox out get your arm up there and have a feel for the little torx screws Razz there's also one or two around airvent too. if thats what your on about anyway.
PostPosted: Tue Nov 22, 2011 9:57 am Reply with quote Up
BigGreenDave wrote:
How!?!?
Try removing the screws & nuts is a pretty good start.
M60SHW
PostPosted: Tue Nov 22, 2011 9:59 am Reply with quote Up
Take a pillow and push the seats right back haha it's painfull
Team, ST
Team, Gti 138 track slag
colinn
PostPosted: Tue Nov 22, 2011 10:19 am Reply with quote Up
Haynes manual identifies the screw locations - when I took mine out I removed glove-box, centre console and the panel at the end of the dashboard first for better access and to get some extra light in there - it's fiddly and you end up lying on your back in the footwell with a torch in your mouth
PugJH
PostPosted: Tue Nov 22, 2011 10:46 am Reply with quote Up
The airbag on the passenger side isnt a cover, its a whole airbag unit.
If thats what you meant.
If not sure its only about 5 screws and a plug you unclip
WIP: Black 1.6 16v XSi
Beauté Noire
PostPosted: Tue Nov 22, 2011 11:16 am Reply with quote Up
Undo the airbag connector and connect the terminals to a 9-14volt battery. That will remove it from it's casing
PostPosted: Tue Nov 22, 2011 11:20 am Reply with quote Up
Multimeter set to resistance setting will give the same result Cool
gazza82
PostPosted: Tue Nov 22, 2011 11:44 am Reply with quote Up
Pretty sure that the dash is wrecked if the passenger air bag does off. There isn't a seam around the cover so it will tear through it if it goes off.
If you are contemplating touching the airbag system, disconnect the battery and leave it for 15-20 mins to disarm itself.
D4NTP
Cant believe you told somebody to do that with out stating its f*****g dangerous! do not put and voltage on to the airbag connections!
If they got hurt because of stupid a**e comments like that...f*****g retards.
PostPosted: Tue Nov 22, 2011 11:46 am Reply with quote Up
Good thing about the 206 is the passenger airbag is just screwed / bolted on & easy / cheap to replace unlike a lot of cars where the whole dash needs replacing when the passenger airbag fires.
PostPosted: Tue Nov 22, 2011 12:19 pm Reply with quote Up
They must be f*****g retards if they do it.
Lecktorious
PostPosted: Tue Nov 22, 2011 12:58 pm Reply with quote Up
Trade Rating: +59
This.
'98 Nile Blue 306 GTi 6
D4NTP
PostPosted: Tue Nov 22, 2011 2:23 pm Reply with quote Up
It honestly wouldnt bother you if someone did what you said (however stupid you may think it is) and seriously hurt themselves?
PostPosted: Tue Nov 22, 2011 2:50 pm Reply with quote Up
Not really. Should always use common sense before doing anything.
  Quick Reply
Username:
Message:
Quote the last message
