Online Now [228]:
Visitors: 227
Today: 38621
Total: 142307103
Forums › The Car › 206 Problems › 206 Boot Rattle
206 Boot Rattle
nellyhaggis
PostPosted: Wed Nov 23, 2011 10:11 am Up
Does anyone know what might be making the rattle in my boot lid?
Its driving me nuts.
Ive had the plastic cover off and cant see anything obvious.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
Antknee
PostPosted: Wed Nov 23, 2011 10:15 am Up
is it when you're driving? could be the boot itself, if it is you can wrap insulation tape around the catch to bulb it out a bit
Might be something in the compartment where the wheel wrench is have a feel in there
Danw_VVT
PostPosted: Wed Nov 23, 2011 10:16 am Up
Is your boot strip cracked or loose? That's what causes mine
nellyhaggis
PostPosted: Wed Nov 23, 2011 10:19 am Up
Yup, when Iam driving.
I will have a look at the strip but prety certain its fine.
Sounds more like something in the boot lid.
Its defo not and wheel keys etc as I dont carry them.
rick-gti
PostPosted: Wed Nov 23, 2011 10:31 am Up
mine is doing the same, sounds like something loose in the bootlid.
i havent had chance to check but i think its the catch worn.
try some insulating tape and see if that cures it.
clio 197sport owner
nellyhaggis
PostPosted: Wed Nov 23, 2011 10:53 am Up
I thought it was the motor on the back of the lock but you cant put tape around it as it has to pop out to lock the boot.
Shortstuff
PostPosted: Wed Nov 23, 2011 11:09 am Up
Mine does it.
Mine is due to missing clips for the boot panel around the wiper motor
Simple fix, just buy new clips
That reminds me :L
Cya!
kristof_clg
PostPosted: Wed Nov 23, 2011 12:33 pm Up
Hi, had the same rattle in the boot, drove me nuts. Finally it was the lock, just loosen the 2 bolts and move it forward or backwards and tighten it again. Try different positions until the rattle is gone.
Wink
206 XS 1.6L 16v
PostPosted: Wed Nov 23, 2011 12:34 pm Up
.....or just turn the little triangle rubbers
kirsteyjames
PostPosted: Wed Nov 23, 2011 12:51 pm Up
I also had this took off plastic panel and couldn't see much. Lent my fathers magnetic retrieval tool, shoved it in the tailgate and gave it a wiggle around and retrieved a nut Very Happy No more rattle!!
nellyhaggis
PostPosted: Sun Nov 27, 2011 2:47 pm Up
Turned out to be one of the nuts that was loose on the lock.
Just nipped it up and silence.
