Online Now [1062]:
Visitors: 1061
Today: 1432
Total: 146456403
Forums › The Car › 206 Problems › engine vibration at 2200 rpm (all gears)
flat-eric
PostPosted: Mon Nov 21, 2011 5:08 pm Up
just recently I have noticed a vibration that comes alive at 2200 rpm in all gears.
most noticably in 5th at 65mph.
if I dip the clutch it goes away
if I drive at 64mph its really smooth
as soon as i go over that its like someone turning on a noisy pump,
the faster I go the less noticable it is? 80 - 90 ish (on private roads) Cool
could this be clutch? or some kind of bearing?
only work I have had done recently is new CAT fitted.
car is a 2.0 HDI SW, serviced regularly 123,000 miles
cheers for looking
Rob
206SW 2.0 HDI - mods to follow
flat-eric
PostPosted: Fri Nov 25, 2011 5:01 pm Up
Anyone got any ideas?
Sad
PostPosted: Fri Nov 25, 2011 5:13 pm Up
Engine mount?
flat-eric
PostPosted: Fri Nov 25, 2011 5:15 pm Up
Lee wrote:
Engine mount?
I thought that at first but it all seams pretty solid.
its the fact it just sudenly appears at 2200rpm that baffles me????
