Latest: SA01
Overall: 17138
Online Now [124]:
Visitors: 123
Today: 41514
Total: 112338226
Forums › The Car › 206 Problems › Cluster Bulbs/Lights/Icons
97browng
PostPosted: Fri Nov 25, 2011 12:32 pm Up
Hi All,
A few months ago I had a problem with my speedo. I ended up replacing the motor and it is working fine now. I also replaced a few of the bulbs in the cluster.
However while I was doing this I noticed there are a load of spaces for bulbs to go which don't currently have anything in. I just wanted to know if anyone had a list or diagram of what should have a bulb in.
I assume that the cluster is made for several models and as mine is the basic it does not use them all. For example I could see that there is a symbol for the 'seatbelt in' but there is no bulb. I guess this is because my model cannot tell if a seatbelt is plugged in or not and therefore does not need the bulb.
I have a 2000(W) 206 1.1 5dr.
Gary
