Posted: Tue Aug 09, 2011 6:54 am |
my 1.4 hdi is making a loud ticking noise would it be the timing belt on its last legs
Posted: Tue Aug 09, 2011 7:28 am |
could be anything mate! Can you be more specific? Ie where from,at what speed,etc etc
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Tue Aug 09, 2011 9:10 am |
why would you jump to the timing belt? if its been replaced at its intervals it will be fine, if it hasnt you should get it done regardless of whether the ticking is that or not
could be the lifters? ive heard other people on here say that they create a loud ticking noise
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Tue Aug 09, 2011 9:28 am |
My peugeot 1.4hdi is making the same sound also very loud id like to know what the problem is also, i was guessing towards the timming belt also as i dont really know if this has been changed in my car.
Posted: Tue Aug 09, 2011 9:39 am |
KARIM wrote: |
My peugeot 1.4hdi is making the same sound also very loud id like to know what the problem is also, i was guessing towards the timming belt also as i dont really know if this has been changed in my car. |
AGAIN MORE INFO NEEDED
Is it ticking from the top of the engine, side of the engine, bottom of the engine????
If you guys want help then give as much info as possible or you wont get the help needed as we dont have crystal balls!!
Posted: Tue Aug 09, 2011 9:40 am |
i know on my old 2.0 hdi that noise means crankshaft bottom pulley but not sure if its same common fault - loud ticking noise on the 1.4 hdi aswell.
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Tue Aug 09, 2011 9:45 am |
voldemort voldemort vol voldey voldey voldey voldemort
Posted: Tue Aug 09, 2011 10:00 am |
Im having my brake discs changed tomorrow by a garage my dads recommended to me and ill have them check this out and if they give me any information on what it is ill post back to you. I cant actually say where the sounds coming from as I dont have the car at the moment but once I do ill post again.
Posted: Fri Nov 25, 2011 11:19 am |
I still have this problem... Changed the timming belt. The sound increases with speed or more accurate the faster i go the faster the ticking sound comes... Sounds as if coming from left side of engine area....
Posted: Fri Nov 25, 2011 4:51 pm |
Sorry for posting again but really want some help as ro wether i should be driving this car as it is or something needs to be changed... Its just come back from mechanic twice had a service and fuel pump + all fuel lines changed... Also just done the timming belt... This car keeps costing me money but id rather fix it then spoil it....
Any help would be greatful.
Karim
Posted: Sun Nov 27, 2011 5:53 am |
the bottom pulley is a comman problem, most people will agree this is the first port of call. remove the aux/fan belt and then run the engine ( for a short time ) see if the sounds changes.
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Sun Nov 27, 2011 6:22 am |
Could be your auxilary belt? That's on the left side of my 1.6 engine, not sure about yours. Mine makes a slight ticking or taping noise in the cold
| EmoStu
Peugeot 206 1.6 XSi Firedance | |
Posted: Sun Nov 27, 2011 3:48 pm |
Thanks for that mate will have to check that out..
Karim
