Posted: Tue Nov 29, 2011 12:35 pm |
hope someone can help me 1 of my fog light not working the driver side does not work i have checked the bulb and the plug and it still does not work can someone please help me
| \"Understeer\" is when you hit the fence with the front of the car.\r\n\"Oversteer\" is when you hit the fence with the rear of the car.\r\n\"Horsepower\" is how fast you hit the fence.\r\n\"Torque\" i | |
Posted: Tue Nov 29, 2011 12:37 pm |
Don't worry about them. You don't need them.
Is it foggy in Skegness then?
Could be a fuse but not sure
Posted: Tue Nov 29, 2011 12:39 pm |
fuse? pretty sure each bulb got it's own fuse.
Posted: Tue Nov 29, 2011 12:40 pm |
no is not foggy is there a picture of the fuse box diagram on here
Posted: Tue Nov 29, 2011 12:41 pm |
How'd you 'check' the bulb? If you just 'looked' at it & didn't light it up, I'd change it. Bulbs can look fine but actully be useless (a bit like blondes).
Posted: Tue Nov 29, 2011 12:42 pm |
| E5GDM wrote: |
| How'd you 'check' the bulb? If you just 'looked' at it & didn't light it up, I'd change it. Bulbs can look fine but actully be useless (a bit like blondes). |
Posted: Tue Nov 29, 2011 12:54 pm |
i put a new bulb in and notting
Posted: Tue Nov 29, 2011 1:01 pm |
| Seabook wrote: |
| fuse? pretty sure each bulb got it's own fuse. |
Nope, there wired in parallel of the same fuse
Posted: Tue Nov 29, 2011 1:03 pm |
| s1mon wrote: |
| no is not foggy is there a picture of the fuse box diagram on here |
If one of the front fogs is working then your wasting your time looking in the fuse box
Posted: Tue Nov 29, 2011 1:12 pm |
I presume you aren't talking about rear fogs?
| The day that Microsoft makes something that doesn\'t suck is the day that they start making vacuums. | |
Posted: Tue Nov 29, 2011 1:17 pm |
There is only one fog on the rear.
It will be a connector or bulb holder issue
Posted: Tue Nov 29, 2011 1:28 pm |
| Lee wrote: |
It will be a connector or bulb holder issue |
Possibly not true, not sure about the 206 but the 306 has a space in both sides for the rear fog, but only the drivers side has a bulb. If you put a bulb in the passenger side holder it will work. I know quite a few people who have done this
Posted: Tue Nov 29, 2011 1:32 pm |
| burnmw wrote: |
| Lee wrote: |
Possibly not true, not sure about the 206 but the 306 has a space in both sides for the rear fog, but only the drivers side has a bulb. If you put a bulb in the passenger side holder it will work. I know quite a few people who have done this  |
Nope 206 only has one fog light,it's in the centre of the lower rear bumper
| Yes I own a CC and I'm neither gay or a hairdresser!! | |
Posted: Tue Nov 29, 2011 1:36 pm |
| fatboyslim wrote: |
| Nope 206 only has one fog light,it's in the centre of the lower rear bumper |
Good point... I'll go and sit in the corner and face the wall!
