Online Now [289]:
Visitors: 288
Today: 7463
Total: 106053328
Forums › The Car › 206 Problems › Clutch just fitted, changing gears is a bit knotty?
Dethnell
PostPosted: Mon Nov 28, 2011 4:54 pm Up
So after getting a brand new clutch 8/10 times changing gear is smooth as silk. However the odd few times it feels a bit knotty trying to change gears.
As far as I know from all the previous jobs that have been done on my 1999 206 at no time has the gearbox oil been changed.
My question being would this be a cheap way to see if I can solve the odd time it stuggles to get into gear before thinking the gearbox might be on the way out?
Thankyou in advance
Very Happy
Rob2859
PostPosted: Mon Nov 28, 2011 4:56 pm Up
You have the wrong gearbox oil. It will only ever be smooth with 75-80.
PostPosted: Mon Nov 28, 2011 4:58 pm Up
he probably still using the orginal gear oil since the car has born
Rob2859
PostPosted: Mon Nov 28, 2011 5:03 pm Up
would have thought it was changed when the clutch was done but he didn't say if he did it or a garage.
Dethnell
PostPosted: Mon Nov 28, 2011 5:06 pm Up
I didn't do the clutch myself, but as far as i know the gear oil has not been changed
Very Happy
PostPosted: Mon Nov 28, 2011 5:10 pm Up
what car what engine?
cable clutch or hydraulic? have you check the gear oil level?
did it happen when down shift or up shift? cold or hot? which gear most likely when it happen?
Rob2859
PostPosted: Mon Nov 28, 2011 5:13 pm Up
I would ask whoever did it if they changed it to start with. It can be that and its the easiest thing it could be.
L5_UKS
PostPosted: Mon Nov 28, 2011 5:27 pm Up
Leave it for Afew weeks and it should settle. Mine was like that when mine was first changed but after Afew weeks it was fine Smile
