Latest: tbafonso
Overall: 17130
Online Now [196]:
Visitors: 195
Today: 78305
Total: 103664069
Forums › The Car › 206 Problems › ECU updates (firmware)
Davels
PostPosted: Sun May 15, 2011 3:15 am Up
So I heard a few people on here talking about getting there ECU firmware updated when trying to find faults. But my question is will an update to the latest firmware really make that much difference?
Also I'm assuming its a dealer only job and I was wondering if anyone has an idea on how much it'll cost. And is the BSI firmware updated at the same time or is this extra?
kieron
PostPosted: Sun May 15, 2011 4:17 am Up
Can lee not do firmware updates? it has to be done with peugeot planet, you will then have stuff like DLR and wiper coming on in reverse if you want
Account suspended
PostPosted: Sun May 15, 2011 4:28 am Up
Lee wont do frimware updates, as he says, if it aint broke, dont fix it!
PostPosted: Sun May 15, 2011 5:36 am Up
No aftermarket place will do firm wire updates. It's dealer only.
It's not worth the risk of corruption of the EEPROM's. If it does corrupt, then I'm like £500 out of pocket.
I'll enable and disable features, but not update.
Davels
PostPosted: Sun May 15, 2011 5:56 am Up
That is fair enough, it was just suggested I update if not already done so to smooth out any remaining rough idle issues after the tappet change.
Lee, in your opinion is it worth getting done at a dealer, surely if they corrupt the EEPROM they would have to replace? I can certainly understand you not wanting that risk. Not cheap!
PostPosted: Sun May 15, 2011 6:02 am Up
People only generally get the BSI updated as the older versions tend to be a bit buggy in their software.
I can't see why you'd need the Engine ECU updating after changing the tappets :/
Yeah if they corrupt it, then yeah they'd either just replace the whole ECU or take the ECU out remove the eeprom and recode it with something like x-prog. I don't know hexdecimal binary so I can't reprogram them Laughing
I'd be tempted to leave it, because I bet its going to cost about £100
stevedude
PostPosted: Sun May 15, 2011 6:06 am Up
also if you get it updated wont that remove any mapping done?
Happydays
Davels
PostPosted: Sun May 15, 2011 6:13 am Up
Cheers Lee, I'll be leaving it I think. I may look at a BSI update later but unless that adds options that can be switched on like autolocking etc there isn't any point.
The ECU update was suggested by a pug tech at a dealership believe it or not Laughing They also said the tappets aren't a known problem. So I was dubious from the start.
But the update was suggested before the tappet work not after to see it that made a difference. But at that point I was 99% sure the they were FUBAR anyway.
PostPosted: Sun May 15, 2011 6:20 am Up
Depends on the age of 2.0 lump Wink
The early ones did suffer for a problem.
Davels
PostPosted: Sun May 15, 2011 6:27 am Up
Seems to be more common on CC's oddly. I know at least 9 other CC 2.0 owners who all had similar idle and misfire problems all attributed to tappets. Mines a 2002 model so not the earliest or the latest of the 2.0 lumps Laughing
PostPosted: Sun May 15, 2011 6:30 am Up
Still falls within the technical service bulliten PSA Peugeot / Citroen sent out Wink
Up to April 2003 EW10 engine production are the lumps affected.
New hydraulic tappet part number is 0942 48
Davels
PostPosted: Sun May 15, 2011 6:36 am Up
Ah nice one, didn't know there was anything official ever mentioned.
And yup they're the ones, just checked the invoice. You had me worried for a sec
dumdum0910
PostPosted: Thu May 19, 2011 3:10 am Up
sorry to hijack thread. how much would a bsi software update cost at a dealer? roughly
Danw_VVT
PostPosted: Thu May 19, 2011 3:20 am Up
Lee if you disable features could you do my rear wiper coming on in reverse for me?
Andrew
PostPosted: Thu May 19, 2011 5:23 am Up
If you have some kind of warranty that will cover it, go for it
I had it done to fix up some start up and idle issues
I don't know how much it would cost without warranty though, ring up a dealer
My 206 thread
www.detailedbyandrew.com
