Latest: Stu-mill
Overall: 17131
Online Now [129]:
Visitors: 128
Today: 21779
Total: 104658063
Forums › The Car › 206 Problems › Engine mount BIG problem
Go to page Previous  1, 2
PostPosted: Sat Dec 03, 2011 4:17 am Up
Seabook wrote:
MrBSI wrote:
macj wrote:
MrBSI wrote:
macj do you have any issues with nuts / bolts coming loose even with threadlock applied?
Yes mate... The two ARB bolts on the rear radius arms, the rear damper bolts. We spanner check before each event now. The engine mount ripped the captive out of the chassis but with the 16swg plate over it there seems to be no further issue
Might be worth looking in to some Nordlock washers, there fitted to a lot of forklifts.
www.nord-lock.com/
Once torqued up these never come undone by themselves.
www.nord-lock.com/defa...rl=2.16.37
would it rip off the contact surface?
You might damage the paintwork as you tighten them up while fitting.
PostPosted: Sat Dec 03, 2011 5:07 am Up
MrBSI wrote:
Seabook wrote:
www.nord-lock.com/
Can't see it doing any more damage than a standard flat washer.
Never heard of them before but look a lot better than the spring washers I'm used to using.
macj
PostPosted: Sat Dec 03, 2011 5:16 am Up
Well worth a try, After about stage 3 the back end is clonking again....very annoying as it may disguise something a little more serious.
gpvecchi
PostPosted: Sat Dec 03, 2011 8:01 am Up
macj wrote:
40mm square with 14mm hole in the centre
Thanks! Thickness?
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
macj
PostPosted: Sat Dec 03, 2011 8:20 am Up
gpvecchi wrote:
Thanks! Thickness?
1.6mm
gpvecchi
PostPosted: Sun Dec 04, 2011 8:02 am Up
Thanks, macj, next week I'll prepare the plate and I'll test it...
macj
PostPosted: Sun Dec 04, 2011 8:06 am Up
You need to weld it in place. I clamped it in place with a bolt and washer to make sure it was aligned correctly, cover everything with a fire-proof blanket to avoid sparks getting in bad places. I would suggest fully welding it in place noce the captive nut is fixed. you can then paint it with a protective coat or two before refitting the mount
gpvecchi
PostPosted: Sun Dec 04, 2011 8:15 am Up
Oh, did you weld it to the chassis? I thougt that you just screwed the mount on it... I think it's just too difficult for my acknowledgment...
macj
PostPosted: Sun Dec 04, 2011 8:22 am Up
You could bolt it in place with the mount..... but fit a self tapping screw in one corner to prevent it turning
gpvecchi
PostPosted: Mon Mar 19, 2012 3:07 pm Up
It seems I finally fixed it! I used an auto-locking nut (the one with a plastic ring) and a big "conical" washer (I don't know the right tech term) screwing the engine mount at about 20kgm instead of 2kgm as garage manual says...
Page 2 of 2
