Latest: S2cgm
Overall: 17178
Online Now [247]:
Visitors: 246
Today: 11421
Total: 137019131
Forums › The Car › 206 Problems › oil light and warning light flashing but oil is full
gavlar83
PostPosted: Sat Dec 03, 2011 8:19 am Up
hi i have a 2004 206 S,and a few days ago the stop warning light and the oil light started flashing,i took the car to my step borthers garage and he said the oil is full and he cant see any problems,i was thinking it might be the computer telling the car its empyt as the right door open warning comes on now and then so i was thinkin it might be related,my brother does not do electrics so i was wondering if anyone on here can help.just to add when i turn the ignition on the oil gauge is saying the car is full
is learning slowly but surely Smile
Signature Removed - Please See Your PM's
PostPosted: Sat Dec 03, 2011 8:39 am Up
The warning light is for low oil PRESSURE Wink
Has it got a genuine Peugeot or Purflux oil filter fitted?
Also open the bonnet & check the oil level with the dipstick, the dash gauge likes to tell lies.
gavlar83
PostPosted: Sat Dec 03, 2011 8:49 am Up
its a purflux 1 mate
gavlar83
PostPosted: Sat Dec 03, 2011 9:07 am Up
also the dipstick is saying its full aswell
ExoVyper
PostPosted: Sat Dec 03, 2011 9:08 am Up
dear god don't drive your car!
low oil pressure will destroy the internals
PostPosted: Sat Dec 03, 2011 9:23 am Up
What He Said
gavlar83
PostPosted: Sat Dec 03, 2011 9:25 am Up
ok thanks for the heads up,any ideas about the problem?
PostPosted: Sat Dec 03, 2011 9:38 am Up
probably need to remove the sump to have a check.
did you used any engine flush by any chances?
gavlar83
PostPosted: Sat Dec 03, 2011 9:42 am Up
iv not used anything at all,it just came on all of a sudden driving home from work
gavlar83
PostPosted: Sat Dec 03, 2011 9:49 am Up
i have spoken to my step brother on the phone and he said if it was the oil pressure there would be a rattle and the engine would be noisey and loud,he cant check it till next weekend so cud do with sum advice,he says its ok to drive but been advised not to by various peole,i ahve work monday so does anyone think i shudnt drive it or will it be ok?any help is greatly apreciated thanks
PostPosted: Sat Dec 03, 2011 9:54 am Up
Under the oil filter housing you will find an oil pressure switch.
Check / clean the connector plug, see if that helps.
If it doesnt then change the switch.
If the oil pressure light has come on, then more than likely damaged has already been caused Wink
gavlar83
PostPosted: Sat Dec 03, 2011 10:06 am Up
i thought the oil light was to say if u needed oil or not,not oil pressure?but im not to sure :)ill have to take it somewhere now as my usual mechanic cant do it till next week and i dont no where the oil switch is
PostPosted: Sat Dec 03, 2011 10:24 am Up
On a modern engine the oil light is generally too late, damage has been done Wink
Oil is the blood of your car. If you cut a vein in your arm, you aren't going to be 100% are you?
gavlar83
PostPosted: Sat Dec 03, 2011 10:26 am Up
i get what your saying,can it still be damaged when the oil is full?also if it is damaged what kind of damage am i looking at?
