Forums › The Car › 206 Problems › 206 CC blower motor |
Posted: Wed Dec 07, 2011 9:41 am |
have a 206cc on an 02 plate with auto digital aircon. The blower is stuck on highest level so after much research am lead to believe the blower motor may need replacing. Is it possible to replace just the resistor on these systems or only the whole motor? GSF have both for sale resistor and motor thanks
Posted: Wed Dec 07, 2011 10:55 am |
I have a used motor in good condition. PM me if interested.
Posted: Wed Dec 07, 2011 1:31 pm |
If the motor is at full blast only it suggest the motor is perfectly healthy. Sounds like the fan controller is at fault.
