Latest: S2cgm
Overall: 17178
Online Now [235]:
Visitors: 235
Today: 2328
Total: 137432178
Forums › The Car › 206 Talk › 206 gti rear beam
206 gti rear beam
rick-gti
PostPosted: Thu Dec 08, 2011 6:51 am Up
could someone tell me what the common problem is with the rear beam on the gti (140) have been told there is a common fault with them.
i plan on buying another gti but it needs a new rear beam.
clio 197sport owner
Big_Rich180
PostPosted: Thu Dec 08, 2011 6:55 am Up
At a guess its the bearing on the trailing arms, they tend to fail.
rick-gti
PostPosted: Thu Dec 08, 2011 8:19 am Up
if thats the case then there should be play in the wheel. how hard are these to change?
only asking as im goin to look at a gti friday and will no whether it needs a new beam or not.
clio 197sport owner
Big_Rich180
PostPosted: Thu Dec 08, 2011 8:37 am Up
Im not sure tbh but i think people charge £400+ to do the job, around here that is anyway.
Id guess once your past the torsion bars it shouldnt be that hard..but that is just a guess.
PostPosted: Thu Dec 08, 2011 9:37 am Up
4 bolts to replace the beam. Brake lines can be a pain though.
rick-gti
PostPosted: Thu Dec 08, 2011 12:06 pm Up
So if I view it and there is play in the trailing arms am I best to walk away? Im not looking to pay much for the car.
clio 197sport owner
Big_Rich180
PostPosted: Thu Dec 08, 2011 1:30 pm Up
It depends on how much the car is and whether you want to do the job...only you can answer that question.
rick-gti
PostPosted: Fri Dec 09, 2011 8:33 am Up
Im hoping to spend no more than £400 for the car. Will have a good look at the beam, im hoping its just the torsion bars that will need removing and refitting.
clio 197sport owner
Big_Rich180
PostPosted: Fri Dec 09, 2011 8:41 am Up
For £400 i dont think you can really complain if its a running car.
Even if the rear beam is on its way out its a £400 car, you cant really be expecting to much.
You would have to remove the torsion bars and the lateral arms then put new bearings in.
rick-gti
PostPosted: Sat Dec 10, 2011 11:38 am Up
Went to view the car today and it needs the bearings replaced on the rear o/s. Keep a look out as I might have a gti for sale after xmas.
clio 197sport owner
rick-gti
PostPosted: Sat Dec 10, 2011 11:40 am Up
clio 197sport owner
