Latest: morgan20
Overall: 17135
Online Now [2925]:
Visitors: 2924
Today: 52011
Total: 110604074
Forums › The Car › 206 Talk › ECU plug
ECU plug
Go to page Previous  1, 2, 3
PostPosted: Fri Dec 16, 2011 3:44 pm Up
PSA Peugeot / Citroen are just slags, they will get together with anybody if there a car company Laughing
Toyota, Ford, BMW, Renault, Volvo, Mitsubishi & Rover, they have all had or still have dealings with / share parts with PSA Peugeot / Citroen.
dumdum0910
PostPosted: Fri Dec 23, 2011 8:16 am Up
Got the plug with that part number and its the wrong plug. Peugeot won't refund it unless ive got the part number for the correct part
PostPosted: Fri Dec 23, 2011 9:27 am Up
What does it look like?
I've bought one before for a MM 68LP
dumdum0910
PostPosted: Fri Dec 23, 2011 12:57 pm Up
i will upload a pic later
dumdum0910
PostPosted: Fri Dec 23, 2011 1:52 pm Up
this is the plug that arrived with the part number
PostPosted: Fri Dec 23, 2011 2:17 pm Up
Why is it red?
dumdum0910
PostPosted: Fri Dec 23, 2011 2:26 pm Up
the red is the rubber seal. the plug is grey with a black clip
dumdum0910
PostPosted: Fri Dec 23, 2011 5:34 pm Up
just having a look on service box and there's 2 part numbers for this plug. the 1 ive got ordered in is 6541 Y8 , could the 1 i need be 6541 Y7 ?
dumdum0910
PostPosted: Wed Jan 04, 2012 1:37 pm Up
im now lost for words. ordered in the other part number from service box and the plug is exactly the same . said to the man in parts its the same and he just said its probably slightly diffrent.
Page 3 of 3
