Latest: Beduff1977
Overall: 17134
Online Now [929]:
Visitors: 928
Today: 86987
Total: 109941746
Forums › The Car › 206 Problems › Engine still runs when turned off !!!
booseph
PostPosted: Tue Dec 06, 2011 3:58 am Up
Hi, I have a 2000 (W) 206 HDI (2ltr) with approx 96,000 miles. The past couple of months I have an intermittent fault were as when I turn my ignition off my engine continues running for 2-3 seconds (gradually cuts out) . When I re start the car the engine management light is on. If I drive steady away (no heavey acceleration) the car seems fine but as soon as I put my foot down a little and my revs increase I loose some power as if in limp mode . I drove 40 miles last night like this still managing speeds of approx 65mph, but this morning the managment light is still on !!!! any help much appreciated , Cheers
J hock
stevesey
PostPosted: Tue Dec 06, 2011 3:33 pm Up
Does the car use any oil?
PostPosted: Tue Dec 06, 2011 4:12 pm Up
Get it code read
booseph
PostPosted: Tue Dec 06, 2011 4:38 pm Up
The engine does use a bit oil , I have just checked it and it seesm fine at the minute.
J hock
millanz
PostPosted: Wed Dec 07, 2011 11:18 pm Up
Can you write the fault code?
206 forever.....
yanto
PostPosted: Tue Dec 20, 2011 3:04 pm Up
fuel preasure regulator fault. the one on the pump
when you switch the car off give the car a little rev and then switch it off.
try it it worked on my hdi
YANTO
