Posted: Fri Dec 09, 2011 5:55 am |
Hello again, just a quick question. The heater control panel buttons in my car dont light up when I turn the lights on. I'm assuming the bulbs have blown but dont know how to change them or what type they are. The panel is the type with an LED type picture of a car in the middle and push buttons around the edge, the temp control is a "rocker" type switch below the display. I have got a picture of the panel, but cant work out how to post it on here!! Thanks in advance for any help. Merry Christmas.
| An Ex '03 1.4 GLX driver, German technology all the way now. | |
Posted: Fri Dec 09, 2011 6:06 am |
Get photo bucket and post it on there then copu the image url to here. I think i have the same issue as you here a link to my thread i started www.206info.co.uk/Foru...ights.html
Mike
Posted: Fri Dec 09, 2011 6:19 am |
Thanks Mike, downloaded photo bucket and have tried what you suggested but no joy posting the pic on here. Hopefully we'll get some answers to our problems, thanks again, Kev
Posted: Fri Dec 09, 2011 6:34 am |
Make sure you click reply not wuick message. Then you will get a bigger option range. Look at message body click the left bottom one then paste the image url in there.
Mike
Posted: Fri Dec 09, 2011 7:27 am |
Posted: Fri Dec 09, 2011 7:28 am |
AARRGGHHHHH why do I get a red cross when I try to post the pic of my heater control panel?
Posted: Fri Dec 09, 2011 7:30 am |
Any ideas how to replace and what bulbs are behind this panel?
Posted: Fri Dec 09, 2011 7:35 am |
you pull out the center console (and poss take out radio) by uncliping the hood/clock cover, and then removing the two torx at top. then if you cant reach behind it you undo the torx on front, push it back and tilt it forward. it quite simple just sounds worse
iirc there are only 3 bulbs, and the buttons bulb is the one at the bottom (all of the buttons share one bulb)
