Latest: tbafonso
Overall: 17130
Online Now [297]:
Visitors: 296
Today: 18347
Total: 104208035
Forums › The Car › 206 Problems › coolant temp?
coolant temp?
wasssssup
PostPosted: Sun Dec 18, 2011 11:45 am Up
hi guys
ever since i have had my gti the coolant temp gauge has always sat dead on 90*c but I've noticed recently its been sitting at 80*c
i was just wondering if anybody else has had this and how they cured it? i going to try cleaning the temp sensor tomorrow see if that cures it otherwise I'm guessing it will need replacing?
on a quest for 200bhp Very Happy
PostPosted: Sun Dec 18, 2011 11:53 am Up
Last time I checked it was freezing outside.
wasssssup
PostPosted: Sun Dec 18, 2011 12:07 pm Up
no sh*t sherlock lol I'm on about when its up to temp the oil reads correct just the coolant reads lower than it should
PostPosted: Sun Dec 18, 2011 12:47 pm Up
Lees point is quite valid.
Your engine temp will be lower in freezing conditions due to the ambient air temperature cooling the radiator more. You'll probably find that even sat in a traffic jam the cooling fan kicks in less frequently than if it was the middle of summer. The car takes longer to heat up and you are also pulling colder air through the heater matrix which has added cooling effect on the coolant flowing around the engine.
PostPosted: Sun Dec 18, 2011 1:08 pm Up
You do know the coolant temp gauge is at the bottom of the rev counter on the GTI?
wasssssup
PostPosted: Sun Dec 18, 2011 1:15 pm Up
Rolling Eyes i give up with this place
PostPosted: Sun Dec 18, 2011 1:17 pm Up
wasssssup wrote:
:roll: i give up with this place
A lot of people have made the mistake & been looking at the wrong temp gauge before on here Rolling Eyes
wasssssup
PostPosted: Sun Dec 18, 2011 1:19 pm Up
its been reading 80*c for about 6 months now even in the crappy summer we had and yes i no where the coolant gauge is I'm not completely stupid lol
PostPosted: Sun Dec 18, 2011 1:35 pm Up
Recently has just turned into 6 months. Were you not concerned about this 5 months ago?
PostPosted: Sun Dec 18, 2011 5:08 pm Up
Wassup I'm on the same boat as you since before the summer on my 1.4i.
Generaly much lower engine temp readings than I'm used to (have the car for 5 years).
It takes ages for it to warm up, and temp sits at 68-70 even after long drive with high load/revs.
It will only pick-up temp when stationary for ages, obviously.
However, I have concluded it is to do with the wax mechanical thermostat in the coolant outlet (~90 C threshold)
and NOT the temp sensor itself, as I have checked with diag tool and sensor seems to be telling the truth.
Haven't got round to replacing it yet but I will in the next couple of weeks along with coolant re-newal, flush etc.
Hope this helps, and never give up on anything mate. Wink
gixxerkev
PostPosted: Mon Dec 19, 2011 1:54 am Up
I think you'll find that Lee & Macca1411 have come up with the correct answer. Its WINTER and Im pretty sure every make of car will take longer to heat up and run cooler when its COLD outside !!! My 1.4 takes twice as long to reach its normal operating temp and also runs about 3-5 degrees cooler even when Im on the motorway!!! Cleaning the temp sensor wont make any difference unless you've not been using any anti-freeze and its caked in lime-scale and crud !
An Ex '03 1.4 GLX driver, German technology all the way now.
gazza82
PostPosted: Mon Dec 19, 2011 8:07 am Up
If the temp gauge is taking a long time to increase or staying low in any weather, it's very likely the thermostat is stuck OPEN! This means the coolant simply gets pumped around and isn't getting a chance to warm up thoroughly. It's a common problem on my Alfa 156.
leigh_boy
PostPosted: Mon Dec 19, 2011 8:32 am Up
geeze its good to have it at 80 over 90 this time of year it will be becasue of the weather but i would test your thermostat if your really bothered as it might be stuck open or not have one at all
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Mon Dec 19, 2011 8:53 am Up
Yep.
PostPosted: Mon Dec 19, 2011 9:25 am Up
I've got a new thermostat to fit to mine this week, cheaper to get a genuine part from a Peugeot / Citroen main dealer then anywhere else Laughing
